streetbob headlight
Old Aug 13, 2008 | 11:40 PM
Ratbasturd's Avatar
Ratbasturd
Originally Posted by carrdoc
want to change bulb first[stock seems to be not so bright]then over winter change entire headlight assem. any suggestions on either/both?
Sylvania H4STBP SilverStar H4 Halogen Replacement Headlight Bulb, 55-Watt/60-Watt
They have a good bright and white light output. Lifespan is on the shorter side, my last one went a little over 14,000 miles.
Old Aug 14, 2008 | 12:14 AM
PigInaBlanket's Avatar
PigInaBlanket
I just bought a Silverstar bulb this weekend and put it in and it is a pretty big difference from the stocker. A lot brighter and whiter light. If you get one make sure it's a H4ST bulb marked for motorcycle use only like in the pic above. I paid $19.99 for it at Advance Auto.
Old Aug 14, 2008 | 03:38 AM
Sumo's Avatar
Sumo
Try fitting one of those new Phillips H4 60/55w +80% Globes
Makes a big difference - we are starting to use a few here in Australia and they are a cheap lighting upgrade
Old Aug 14, 2008 | 06:46 AM
shimmon's Avatar
shimmon
i just intalled a fatboy/softail headlight on my bob... it is a 7" light, and makes a big difference in lighting and looks. got it off ebay for 30 bucks, and am going to install a sylvania silverstar h6024ST bulb here tonight, that sealed beam bulb was 19.99. the fatboy/softail 7" light bolts right up and uses the stock connector, you have to remove the crimp on ends to get the wires out of the stock headlight housing, and put in new housing and put back in connector. eveything will work just like normal.
also i think you can buy the fatboy/softail housing from j &p pretty reasonable and put any h6024 bulb in it for way less money than any aftermarket HD lamp!
Old Aug 14, 2008 | 06:48 AM
shimmon's Avatar
shimmon
i dont have any pics yet of it, will here soon though, if you want to see some pics just search it out. i think it was kiwi who had done it a year or so back.
Old Aug 14, 2008 | 06:53 AM
shimmon's Avatar
shimmon
https://www.hdforums.com/forum/showt...adlight+street
here ya go there is a pic the fatboy headlight... also if you search "fatboy headlight dyna" you will see thread asking for pics of different headlight on dyna bikes, plenty of pics and idea there
Old Aug 14, 2008 | 07:56 PM
OLDED's Avatar
OLDED
Default H3 bulb
I went to Autozone and bought the higher intensity version H3 bulb off the rack and it is a lot brighter - about $20.00. It says on the package it is for a motorcycle. If it isn't about $20.00 it isn't the right H3 as there is a lower power version at about half that.
Old Aug 14, 2008 | 08:58 PM
PigInaBlanket
Are you sure the H3 was for motorcycle use? I believe the H4ST is what you are supposed to use.
Old Aug 14, 2008 | 09:15 PM
YoungGun's Avatar
YoungGun
Originally Posted by rowo
Depending on the color of the bike the Head Light Trim Ring from HD might be an alternative.
It looks good on my Dyna IMHO. More photos here: https://www.hdforums.com/forum/members/69537-rowo-albums-97-2007-dyna-street-bob.html.
Now that's the ticket, i was looking for something just like it for my ride, I cringe every time I ride at night with the darn stocky that is on it now, If it were not for the inverted driving lights I would be running over all the criiters on the back roads here.
Old Aug 15, 2008 | 10:06 AM
coastrider's Avatar
coastrider
Default headlight
I didn't like to stock light. Looks like a cheap afterthought. I scrapped mine for a flat black aftermarket billet light. Looks a lot better with my blacked out SB.
Ride Safe.
