REAR Brake is gone
Old Aug 20, 2008 | 04:32 PM
BoomSoon's Avatar
BoomSoon
Default REAR Brake is gone
07 SB with about 7500 miles. A few weeks ago rear brake got soft. After pump a few times it works. Dealer said bubble, bled it, helped a little. A week later a buddy bled it, it has plenty of fluid and same thing. Its actually worse now. I'm thinking master cyl??? Its under warranty. Any thoughts?
Old Aug 20, 2008 | 04:45 PM
jsbridgew's Avatar
jsbridgew
no leaks?
Old Aug 20, 2008 | 05:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Yep, I would have the dealer check out the master cylinder. If the pedal is going soft it's usually the fluid going around the seal on the piston and creating any pressure to operate the pads in the calipers. Yep, time for the dealer
Old Aug 20, 2008 | 05:45 PM
Bluesssman's Avatar
Bluesssman
When you pump the brake, will it slowly go down and down. If it does it really says the master cylinder needs to be rebuilt or replaced.
Old Aug 20, 2008 | 05:54 PM
seniorsuperglideE8
Yep that's what I tried to say but I forgot one word..."not" creating pressure. oops.
brakes
Jul 15, 2017 11:07 AM
rustang
Apr 12, 2014 11:12 PM
Steen
Jan 29, 2014 06:23 AM
GLIDEGASM
Wheels/Tires
Aug 7, 2013 07:43 AM
Timboto
Shovelhead
Sep 18, 2007 10:42 AM
