Made some changes this winter, just got back on the road today.
This is my favorite street bob
hands down. Been following your build on chop cult. Did you decide on a tank? I'd love to know what rear shocks your using. What intake set up that looks like a carb. And what front end did you use. Again hats off!!! Be proud. I hope one day I can there.
WOW!!!
This is definitely THEE sickest Street Bob I've ever seen!
Great job and love the front end, very retro, the rear fender is perfect... just a great just here!
I will eventually cut out the backbone, replace it with round tubing, and change the tank, but now thats its running again I won't dive in to that until the cold wheather comes around again. The rear coil overs are from Progressive and they are shorter and have higher spring rate than stock. The trees are from Mullins Chain Drive, tubes are 39mm and the legs are Showa's that where shaved by Nick @ Wargasser. The spool hub is also from Wargasser. Thanks for the compliments.
here is the difference in trees
Appreciated guys,
No!!!!!!!!!
