T.C. stage 2
Old Mar 24, 2006 | 02:32 PM
sporty2003's Avatar
sporty2003
Default T.C. stage 2
has anybody had this done on there twin cam i would like to leave it at 88 but take care of the rest put the better valve train in it more cam i live in the same town as the king of cubes better known as hyp-peformance and looking at about $3500 to do it . but i would like some input on this and see what you all think of the ideal.?
Old Mar 24, 2006 | 03:00 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: T.C. stage 2
Not me.....I'm just working up the ***** & the bucks to Stage 1 mine......
Old Mar 24, 2006 | 09:49 PM
CraigC's Avatar
CraigC
A Stage II on your 88" would just be a Stage I with a cam swap. Should be FAR less than $3500! My Stage II 95" kit will only be $1600 installed, parts and labor. Hell, you should be under $3500 to do the big bore Stage II and HTCC heads too.
Old Mar 24, 2006 | 10:33 PM
JonHanna's Avatar
JonHanna
I'm saving for my 95" stage 2 kit now
Old Mar 25, 2006 | 01:36 AM
CraigC's Avatar
CraigC
I'm ready to proceed with mine, without pipes. Harley has a map for the kit with stock mufflers so it should run fine. I'll put the pipes on and retune when I get them. Just tired of waiting. I'll let everybody know how it turns out.
Old Mar 25, 2006 | 03:00 AM
Cabo's Avatar
Cabo
Does any of this void the warrentee or is it cool if HD does the work?
Old Mar 25, 2006 | 06:13 AM
rastas's Avatar
rastas
i'm about 2-3 weeks away from 95cub,203 cams flow the heads flat top pistons and SERT+dyno(25 degree injectors).my dealer has stated if all parts are SE or harley warranty will stay in tact.
Old Mar 25, 2006 | 12:40 PM
CraigC's Avatar
CraigC
The stealer is doing the work and the warranty will be intact.
w4hyi
2014-2024 Touring Models
Mar 5, 2015 05:57 PM
Ray Armstrong
Feb 15, 2015 11:10 AM
EdandGrace
Aug 26, 2013 10:16 AM
billybob194
Jun 1, 2009 09:45 PM
rockon
May 24, 2008 02:36 PM
