08 street bob wont idle
Old Sep 5, 2008 | 07:44 PM
evad5150's Avatar
evad5150
Default 08 street bob wont idle
Just turned 1000 miles and now this happens. starts and runs fine until I shut it off and try to restart it (even after over an hour) then I need to give it some throttle to get it running and then it wont idle, it just stalls if I let off the throtttle. and the engine light pops on but will go off if I twist the throttle a bit to get the idle up. and I have oil dripping out of my air cleaner. I know this has been an ongoing issue with Harleys but I thought they licked this problem on the 96 inch motors. Any thoughts.
Thanks
Dave
Old Sep 5, 2008 | 08:04 PM
FATBOB.'s Avatar
FATBOB.
usually when you have too much engine oil, it will drip out of his air cleaner.
it happen to a friend. he had put too much oil after his oil change...after taking
some oil out this stop.( oil leak )hope this will help.
keep the shiny side up..
Old Sep 5, 2008 | 10:08 PM
joejoesport's Avatar
joejoesport
my sporty used to do this also. turned out it was running pretty lean and was getting too hot. sometimes i would have to let it sit for 3-4 hrs before it would run right again. might also be a fuel delivery problem (possibly electrical)
Old Sep 5, 2008 | 10:22 PM
benwiggin2's Avatar
benwiggin2
Take it back!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 5, 2008 | 10:30 PM
chad peterson's Avatar
chad peterson
Yep, take it back & let them worry about it! Well within warranty, and no need for you to waste your time chasin the problem.
kenny55
2018+ Softail Models
30
Jul 20, 2022 10:54 AM
surger45332
Oil Archive (no new posts)
May 12, 2014 06:47 PM
surger45332
May 12, 2014 04:25 PM
trigg
Jun 13, 2012 04:47 PM
hitchhiker2706
Mar 16, 2008 08:53 PM
