dyna07 fuelpack
Old Sep 7, 2008 | 10:36 AM
straniero's Avatar
straniero
Default dyna07 fuelpack
hi i have some questions, in my dyna superglide 07 with fuelpack and straightshots hs slip ons and screamin eagle air filter with active airbox bypass, map fp-0602 , i would like to know do i have to eliminate o2 sensor for better results? or do i have to let stock?
Old Sep 7, 2008 | 10:55 AM
scotsport's Avatar
scotsport
NO - don't do it! The Fuelpack works mainly in 'open loop' (higher engine loads & speed). The O2 sensors look after the AFR in closed loop (lighter riding conditions). The Fuelpack assumes the O2 sensors are still there.
If you wan't cooller running in closed loop at reasonable the cost the Nightrider IEDs work a treat and are compatible with the FP. I've been running the set up all this year and it works a treat.
Do a search on Nightrider IED's.
And leave these those O2 sensors alone for a simple, inexpensive stage 1 set up.
Hope this helps.
Old Sep 7, 2008 | 11:05 AM
straniero's Avatar
straniero
i like the setting with the map fp-0602 but lately i have some error in my engine p0154 what can be? and what i have to do?
Old Sep 7, 2008 | 12:01 PM
BluBob's Avatar
BluBob
Here is a code list. PO154 is Rear O2 Sensor Open/Not Responding
File Type: pdf
Old Sep 7, 2008 | 12:41 PM
straniero's Avatar
straniero
thanks can be possible is unplugged? where is located at? i cant find
Old Sep 7, 2008 | 02:51 PM
benwiggin2's Avatar
benwiggin2
the actual sensor is threaded into your rear cylinder exhaust pipe, above your oil filler location, and wiring goes to a weatherproof plug up under your seat. Pretty easy to trace. Probably not unplugged, but worth checking.
Old Sep 7, 2008 | 03:11 PM
straniero's Avatar
straniero
if is not unplugged what can be the problem?
Old Sep 7, 2008 | 03:28 PM
benwiggin2's Avatar
benwiggin2
faulty sensor...
AKL1
Jan 19, 2020 03:03 PM
moloprintz
Apr 4, 2013 09:59 PM
olsenjb
Mar 10, 2012 08:57 PM
Mechano
May 21, 2009 02:25 AM
PB565
Mar 17, 2008 09:03 AM
