nothing wrong with torx once you invest in a good set of torx.i whined bout em myself in the past.as said before you gotta use the correct size also
I agree with you, a good RIGHT SIZE bit will get the job done. Personally if i even sense a torx screw will not break loose i use my good ol impact driver, typically one good hit with a hammer and the cam action of the impact driver breaks it loose easily.
Yep, the right size if critical. Torx is very unforgiving of the "this size is close enough" syndrome.
And some of the sizes are so close together it's hard to tell if you have the right one or not.
Sometimes it fits pretty good, but then when you strip it out you realize it wasn't the exact right size.
