ISO grip install problem.
Old Sep 17, 2008 | 07:16 PM
drhooligan's Avatar
drhooligan
Default ISO grip install problem.
I'm trying to install a pair of Kuryakyn ISO grips(#6205) on my 07 FXDWG and am having a problem with the throttle grip binding and not returning when released. It seems as if the inner rubber, recessed edge on the ISO grip where it meets the switch housing is rubbing. I was thinking of using a razor knife and removing this small rubber lip on the inner edge of the grip where it meets the housing. Anyone else have this problem?
Old Sep 17, 2008 | 07:28 PM
tlb's Avatar
tlb
I did and it was my cables and not the grip. I lubed the hell out of the cables and took lose the zip ties and reset everything back up until it no longer got in a bind.
Old Sep 17, 2008 | 11:27 PM
MidnitEvil's Avatar
MidnitEvil
Just on a goof - did you check your thumbscrew and make sure it didn't get turn in while you were working on everything?
Old Sep 17, 2008 | 11:29 PM
Bluesssman's Avatar
Bluesssman
I would check your cable installation before I started cutting anything on the grip.
Old Sep 18, 2008 | 12:55 AM
rounder's Avatar
rounder
heres one for you... did you pull the grip and assembly back 1/8" from the end of the bars.... That will fix you up!
but the end of the grip to the handlebar then pull away the 1/8 an inch.
Old Sep 18, 2008 | 06:12 AM
Rauzer's Avatar
Rauzer
Thats exaxctly what was binding mine. I had to move the whole switch assembly back just slightly and it worked fine.
Old Sep 18, 2008 | 10:24 AM
drhooligan's Avatar
drhooligan
I guess that means that the ISOs are just slightly shorter on the inside where the bars goes than the HD stockers.
Thanks guys, I really appreciate the help and suggestions, what a great forum!
Old Sep 18, 2008 | 08:38 PM
drhooligan's Avatar
drhooligan
That solved the problem in short order! Moved everything about 3/16" and no more binding. Great, thanks!
Old Sep 18, 2008 | 09:05 PM
rounder's Avatar
rounder
your welcome... FWIW it's a step in the service manual...
TennesseeMustangPerf
Sep 24, 2011 02:15 PM
drhooligan
Sep 17, 2008 07:26 PM
rbabos
Nov 12, 2007 06:25 PM
flynavy
Sep 17, 2007 12:51 PM
Woodchuck
May 21, 2007 07:34 PM
