Front ends and floorboards
Old Sep 20, 2008 | 06:17 PM
cflchurch's Avatar
cflchurch
Default Front ends and floorboards
three questions for ya'll, first one is , does anyone have a roadking front end on there dyna? two, does anyone have floorboards on an 07 or newer? and i mean the police kind , like the dyna defender. and could i mount those on an 08 superglide? lastly, has anyone seen or know how to put a gsxr inverted front end on a dyna or harley for that matter? triple trees etc...? thanks , and i know its a wide array of ? thannks to all..... brian
Old Sep 20, 2008 | 07:15 PM
ackman1968's Avatar
ackman1968
To get the Road King look you would have to use a FL Softail front end. It is not bolt on but can be done. The Dyna floorboards I understand will work but once again not 100% bolt on. Couldn't tell you about GSXR parts on it though.
http://www.kenandjudy.us/MyHarley.htm
Not mine but shows it can be done.
Old Sep 20, 2008 | 07:18 PM
Rancid17's Avatar
Rancid17
I don't know about the front end, but I'm pretty sure that lolife has boards on his bob, might want to pm him about it. I know someone else has a writeup for putting boards on as well. I know the search is messed up right now but might try it out and see if you can spot it.
Old Sep 20, 2008 | 07:32 PM
cflchurch's Avatar
cflchurch
thank you both for your quick responses and ackman1968 great website thats what im looking for , i wanted a gsxr front end because it is super light and performance oriented, i like my harleys fast, light and able to habdle. i live in pgh , pa so roads are bad.
Old Sep 20, 2008 | 10:02 PM
ackman1968's Avatar
ackman1968
There's a set of floorboards on ebay right now. Here's the link.
http://cgi.ebay.com/ebaymotors/harle...QQcmdZViewItem
Old Sep 21, 2008 | 02:53 AM
SURFOR Chop's Avatar
SURFOR Chop
As ackman1968 states you'll have to go with a FLST (Softail) front end ... a Road King front end will not work due to differences in front end geometry.
I followed suit after Ken Ridout (the guy whose website shows the front end conversion) and installed an FLST front end on my '05 Super Glide.
I got deployed before I had a chance to put on a wheel and fender. Will be finishing the project presently. I am planning to finish the job with a nacelle (headlight housing).
A couple of photos show the options. The nacelle pictured is a aftermarket (Rick Doss) version of P/N 67907-96B – Zanotti H-D (www.zanottimotor.com) $336.00.
You'll need to either replace the fender with a Heritage/DeLuxe style fender (pictured) or a Fat Boy style fender. Or you could use a pre-'06 Wide Glide (or narrow glide with spacers) fender.
Another option to the '04 and earlier FXDP style floorboards is to use FLST floorboards. I could send you details or also check out forum member CStolp (Chris Stolp) ... he manufactured an adapter and did a pretty good post.
The easiest and cheapest option is to go with the floorboards that replace your pegs. They can be gotten from J & P Cycles among other sources.
Can't help with the GSXR front end concept ... Best of luck
R/
Priest
Attached Thumbnails Front ends and floorboards-fl-front-end.jpg   Front ends and floorboards-nacelle.jpg   Front ends and floorboards-fl-fender.jpg
Old Sep 21, 2008 | 04:53 AM
SURFOR Chop
Keeg has a set of FXDP boards on his '07 Street Bob and did a post on how-to do the 'work around.' Take a look at his signature photo and if you can find his post using the search function, it'll show how he adapted the Police boards on his bike.
I test rode a Dyna Police bike with the floorboards just to try them out ... I was sorely tempted to go that route when I figured out how to adapt Softail boards.
I've attached an old photo of my bike with boards, but before changing out the front end ... you can see what my floorboards look like (I've used the old-style half moon boards).
R/
Priest
Old Sep 21, 2008 | 11:27 PM
ackman1968's Avatar
ackman1968
You know Harley could make this much easier if they would just build us an FLDC. I have the front end and my intention is to install it this winter. I was also going to do the Softail boards but I need to go one thing at a time. Right now it is getting the GTO sold so I can but more parts. I did notice that the tubes are about an inch shorter than the ones on my 06 but I wanted to lower it a little anyway.
Old Sep 22, 2008 | 12:00 AM
rockon's Avatar
rockon
Forumite keeg has put the FXDP boards on his Dyna....the kit is now obsolete and no longer sold by HD....occasionally a complete kit can be had on eBay, and he can probably give you the individual parts #'s if you want to piecemeal it together.
Other kits have been used off JPCycles, Stanger has done it with his...just might take some extra work.
Old Sep 22, 2008 | 04:11 AM
Roadman56's Avatar
Roadman56
http://www.storzperf.com/jpgs/page11.html Inverted front end
