cam cover question
Old Sep 25, 2008 | 09:27 AM
rounder's Avatar
rounder
Default cam cover question
does it require draining the oil to remove the cam cover... I feel it doesn't but am unsure...
Old Sep 25, 2008 | 09:31 AM
splitting_lanes's Avatar
splitting_lanes
nope.
just take it off.
you'll need a new gasket and the torque sequence to put it back on though...
Old Sep 25, 2008 | 01:49 PM
dyna07custom's Avatar
dyna07custom
No thats where ponts used to be no oil
Old Sep 25, 2008 | 02:48 PM
bberck's Avatar
bberck
You will lose some oil when you take it off but dont think you need to drain it.
I had mine drained when I took mine off because I was changing all the covers and still it made a mess.
Old Sep 25, 2008 | 03:56 PM
jmpancoast's Avatar
jmpancoast
If you need it....
Old Sep 25, 2008 | 05:06 PM
manofsteele2003's Avatar
manofsteele2003
Good info.
Old Sep 25, 2008 | 06:00 PM
tideglide's Avatar
tideglide
Yep, same here. I don't know if there would have been more oil if I hadn't already drained it.
Old Sep 25, 2008 | 06:08 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If you can do this, put the wheels on peice of wood about a 1/2 inch thick with the jiffy stand on the ground. This will cause the bike to lean a little bit more causing the oil to drain out of the cover to the engine case, it's not much oil but enough to make a mess, a old drain pan to catch the dribbles would be good too.
Old Sep 25, 2008 | 06:27 PM
2005UltraNC's Avatar
2005UltraNC
Put some rags under the cover and just take off - will lose like couple tablespoons of oil.
Old Sep 25, 2008 | 07:13 PM
Dizzzy's Avatar
Dizzzy
Are you taking off the cone..or just the "points" cover? Points cover no oil...its empy. The cone is a different story
