winter oil change question
Old Oct 4, 2008 | 07:43 PM
spiker's Avatar
spiker
Default winter oil change question
I decided to store my 06 super glide for the season,it's a little less chill on my bagger this time of year in Wisconsin.I have 1200 expressway miles on the last oil change,should I just leave it in?just change the oil?or do both?If just the oil,do i take the filter off and empty it out?might sound kind of cheap but i use a premium filter an Amsoil,so I'm trying to save a few bucks.Any advice would be appreciated. Thanks-Spiker
Old Oct 4, 2008 | 08:00 PM
06dynablack's Avatar
06dynablack
Id change both if your done riding it for the season
Old Oct 4, 2008 | 08:14 PM
maddghost's Avatar
maddghost
both! if you leave the old filter next season you will want to change it out before the oil is due!
Old Oct 4, 2008 | 08:26 PM
man4mopar's Avatar
man4mopar
Do what you want. But if I only had 1200 miles on the oil and filter change I would leave it be. Then when time to bring it up I would check the oil for moisture(Changed or not changed), if it looks like chocolate milk, change oil. And unless you park it in a very flooded humid building or lake I doubt you will see moisture in the oil. Again do as you want there is no advantage either way accept one way uses less resources.
Later
Old Oct 4, 2008 | 08:33 PM
06dynablack
what about the acids and were not talking the barrell kind lol
Old Oct 4, 2008 | 11:12 PM
robzuc97's Avatar
robzuc97
If you're not using a battery tender but starting the bike periodically to keep the battery charged, leave the semi-new oil in. If not drain well otherwise the crap will settle in your crankcase. Bad ju-ju!
Old Oct 4, 2008 | 11:15 PM
Kagan's Avatar
Kagan
Later
"Then when time to bring it up I would check the oil for moisture"
Um, too late. Change in BEFORE storage.
Old Oct 4, 2008 | 11:18 PM
Kagan's Avatar
Kagan
"starting the bike periodically to keep the battery charged"
Do people still actually do this? This was supposed to have died off as a myth along with burning witches at the stake. It doesn't work folks. Buy a Battery Tender and leave your bike alone.
Old Oct 5, 2008 | 12:08 AM
RAWHIDE07's Avatar
RAWHIDE07
You already know the answer to your question,right?Spend the big bucks($40) on your expensive motorcycle because it depends on YOU to take care of it.
Old Oct 5, 2008 | 12:25 AM
man4mopar's Avatar
man4mopar
Too late for what? Moisture? whatever. Maybe I should have wrote enough moisture to cause concern. Again do as you wish, no advantage either way. If it did then we would be changing a lot more oil and filters here in the Antarctic when parking vehicles for a season or years on end. Snow gets into everything here, and rarely is there enough moisture in the oil to cause concern.
Classicfc
Jun 19, 2012 01:40 PM
dub976
Oct 3, 2010 10:09 AM
Hog Heaven
Apr 14, 2010 09:48 PM
Catfish57
Nov 22, 2008 12:35 PM
anubisss
Jul 11, 2007 09:00 PM
