traffic lights not changing
Old Oct 8, 2008 | 07:05 AM
2007fxdc's Avatar
2007fxdc
Very inconsistent around here. Some will change, some won't. We also have a new law that allows us to run the light after waiting a reasonable amount of time and nothing is coming. I don't recall the exact time limit. I've heard people say to try to get as much metal as close to the sensor lines in the pavement as possible. Don't know if that makes a difference or not.
Old Oct 8, 2008 | 08:25 AM
Prodriverdon's Avatar
Prodriverdon
+1 on the red light tripper sold on-line. THEY WORK.......
Old Oct 8, 2008 | 08:38 AM
Binny's Avatar
Binny
.next time you all pull up to those lights that don't change, take note and you will see some cuts in the pavement.[very nice straight cuts] Under those 'cut' lines are wires that sense pressure and let the trafic controller know something is there..[it is a closed loop circuit].....
..bikes are generally not heavy enough to trip the wire and close the circuit.....I have found that if ya line yer tires up on the 'line' they will trip the circuit .....cars do it anyway since they are so heavy.....kinda like a security gate that mysteriously opens............some states use a photocell sensor, some states put wires in the pavement system.....
The other alternative is to pack a real 'big mama' on yer ride so ya got more weight....but we all know that really hurts the 'weight to HP ratio'.......Binny
Old Oct 8, 2008 | 08:57 AM
AbqDave's Avatar
AbqDave
Sometimes, when I blow through the light, I say to myself, the universal rule is, when traffic lights malfunction they are treated as 4 way stops. The rest of the time I say something along the lines of "screw this."
Old Oct 8, 2008 | 09:48 AM
thebump's Avatar
thebump
http://www.greenlightstuff.com/trigger.html
I bought this and it works every time now. You need to roll up on the light slowly though. If you go to fast it still don't work. But if you just go easy into the light, it will trigger. I love this thing.
Old Oct 8, 2008 | 09:55 AM
SC-Longhair's Avatar
SC-Longhair
Most bikes are not heavy enough to trigger the traffic sensor. Here in SC, the gov. just signed into law that motorcycles can make a left on red after waiting 120 seconds, and checking traffic flow. You wouldn't want to turn left into oncoming traffic. You are then supposed to report the faulty sensor to the state and they will fix it.
Old Oct 8, 2008 | 09:56 AM
rhinoWErX's Avatar
rhinoWErX
Another trick - that seems to work for me - is the put the bike on the side stand - with the stand resting in the sensor area. Seems to trip the light with no problem.
Or get of (or have your passenger get of), walk over and press the crosswalk signal button
Old Oct 8, 2008 | 10:00 AM
jstreet0204's Avatar
jstreet0204
It is my understanding that the sensors are not based on weight but are magnetic sensors. There simply isn't enough steel in the bikes to trip some of them which is why the magnets work.
Old Oct 8, 2008 | 10:12 AM
rhinoWErX's Avatar
rhinoWErX
Right, and the side stand on the deck helps pick up the signal - or so I thought.
As mentioned by RudeDog before, I guess there are many different types. And while I suspect all new road construction adopts the newer technologies, the roads in my area haven't been upgraded, that I know of, in over 20 + years...
Old Oct 8, 2008 | 10:28 AM
thomaskray's Avatar
thomaskray
just use a remote control that will turn the light green before you even stop. Attach it to your bars.
http://www.youtube.com/watch?v=NqmNe76HVhk
