traffic lights not changing
I have the same issue here in NorCal, honestly, I'm just sick of waiting for cars to arrive behind me so that I can go home...
If a cop sees you flick him off and speed away...
I tell you... you would think an instruction manual would come with every Harley, guess most don't read the fine print..... LOL
They are electromagnetic interrupter loops. Basically, they create an electromagnetic field. Large metal objects interrupt this loop, tripping the light. Bikes are often times not enough metal to trip them, or some sit too high, etc. Getting closer to the line helps some, rolling back and fourth over it does too. The online magnet things work, too. Whoever said you should talk to your city/county important people about getting them adjusted, as, yes, they are adjustable.
its due to lack of ferrous metal, but the magnet make the field flux enough to trip the circuit.....so if you where on a geezer glide you could just pump up the volume on your stereo and the light would change!!!! wait....maybe not
The intersection next to my house uses an inductive loop trigger. It bugged the crap outta me. I bought a Green Light Trigger over a year ago and mounted at the lowest point on my frame that I could. That little magnet does its job perfectly. Now the light knows I've arrived and I get my fair turn at a green every morning....
I recommend them to anyone that asks. They're cheap, easy and they work (if you can mount it low enough to overcome that pesky "square of the distance" rule).
*edit* attached a pic of the trigger for those that might be curious. It's small, black and blends into the frame. You'd never know it was there if you didn't know where to look. Check out the small square bump just in front of my side stand.
