Goofed up while installing pipes
Old Oct 10, 2008 | 01:56 PM
hardluk1's Avatar
hardluk1
They will be lay'n on top of the final drive belt right up next to the front pulley . I know i have done this atleast 7 or eight times through the years and they always end up there. If youhave a jack or a long legged friend hold the bike upright and with a good small flash light you can look under the left side under the belt and look forword and see them. Magnet them out.
Old Oct 10, 2008 | 02:03 PM
FolsomPrisonBlues's Avatar
FolsomPrisonBlues
Can't tell u how many times I've done it. Sometimes I find 'em, sometimes I don't. It won't hurt anything & will fall out the next time you ride.
Old Oct 10, 2008 | 03:33 PM
r00k's Avatar
r00k
Did the same thing with the seat bolt, right after i get home from my first ride afterwards the bolt is sitting right in front of my driveway.
It was convenient.
Old Oct 10, 2008 | 04:36 PM
Tech23's Avatar
Tech23
Originally Posted by SH_01FXDWG
Hey guys, while putting my sideshots back on I dropped two nuts. I was struggling trying to get the upper nut on the back cylinder. After dropping the first one, I should have got up, and came back later cause it was pissin me off. But no, I tried again with a different nut, and well, like I said above, I dropped two nuts Anyway, they did not hit the ground. I think they fell down on the primary side in that cavity were the shifter lever is. If I left them would they maybe just fall out? or could cause some damge down there?
I bet they fell down under the starter solenoid.
Old Oct 10, 2008 | 08:05 PM
Naz_Man's Avatar
Naz_Man
I've did this myself but only once and I learnt my lesson. I tried with the magnet and couldn't find it. I fired up the air compressor and was able to blow it out. But from now on I lay a towel or a large rag over the motor and trans that way if it drops it lands in the towel and it's very easy to get.
Good luck, Donnie
Old Oct 10, 2008 | 08:29 PM
Tech23's Avatar
Tech23
Good luck, Donnie
The rag is a great idea, and I started doing that after dropping one of the rear tank mounting aluminum flange washers down in there. If you've got a compressor have at it.
Old Oct 10, 2008 | 08:35 PM
SH_01FXDWG's Avatar
SH_01FXDWG
Well, all is back together now. I found one of them, funny thing is I spotted it as I was walking up to the bike. And get this, there is a rubber hose just in front of where you add oil, the nut was on top of that hose. Don't know how I did'nt see it last night. No luck on the other one. I looked all over for it. I jacked the bike up and spun the rear wheel. Nothing clanking around, and no binding. I even leaned the bike over, almost laying it down to see if I heard it, or maybe it would fall out. Nothing. Oh well, maybe it fell out and rolled to the next county! Who knows. Anyway, thanks for all the input. Much appreciated!
Old Oct 10, 2008 | 09:46 PM
MattsFatBob08's Avatar
MattsFatBob08
Default 2 NutS
You finally dropped 2 nuts. Congratulations. I dropped 2 nuts when I was 11 or 12. But now you say the 2 nuts are lost. Good luck finding them. I keep mine in a protective bag......
predatornut
Apr 9, 2017 09:08 PM
Dustin5
EVO
Aug 23, 2016 05:30 PM
noridinsavage
Electrical/Lighting/Alarm
Apr 26, 2012 01:20 AM
Pidgin
Apr 21, 2008 01:38 PM
papamonkey
Sep 1, 2005 02:19 PM
