Anyone put Deuce Risers on their Low Rider?
I want to go with a Higher Riser to install my Buffalo Drags but here's the problem:
The FXDL handlebar clamp has that DERANGED bolt pattern... you CANNOT use the clamp with standard Risers, and the clamp has the indicator lights in it. I went through A TON of crap on my 1200C with this problem and ended up relocating my Indicator lights....I don't wanna go through THAT again!!!
I noticed that DEUCE Risers SEEM to have that same straight up and down bolt pattern that the FXDL risers have and they are a 6" pullback riser. If they fit the FXDL clamp they would be PERFECT!
Anybody???
I'm thinking of the deuce risers on my Superglide, after I move the speedo.
Can't answer your question specifically - but the deuce trees are different and you will have to modify the risers to make them work on a dyna by hacking off the collar at the bottom.
I have a set of Deuce risers on my FXDL. Let me know if there are any specific
measurments on the clamp that might help you.
I would like to use the deuce risers on my 2007 fxdl could you tell me the distance from top to bottom bolt hole center on the clamp hoping to use stock clamp
