replacement tires
Old Apr 2, 2006 | 11:28 PM
wideglidedan's Avatar
wideglidedan
Default replacement tires
Just wandering what kind of tire I should use for replacements on my wide glide? Whats your thoughts guys? Thanks.
Old Apr 2, 2006 | 11:35 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: replacement tires
Tire manufacturers have different standards.... What are you looking for?
Dunlop or Continental - Good all around wear... fair wet weather handling...
Metzler - Great wet traction compound... Lousy wear characteristics... Fantastic grip on the twisties
Pirelli - See Metzler ... Worse wear characteristics...
Old Apr 3, 2006 | 12:01 AM
Bigbird's Avatar
Bigbird
It depends on how hard you ride. I really like to hammer turns so I use the Metzlers or Avon Venom. The Avon Venoms wear really fast but stick like glue.
Old Apr 3, 2006 | 12:10 AM
RudeDog's Avatar
RudeDog
I've used Avon Roadrunners for many years and they've proven to be superior wet weather traction. I hear Venoms and Metzler 880's are good also. If you don't ride in the rain then go with Dunlops for the extended wear.
Old Apr 4, 2006 | 11:32 PM
wideglidedan
just stock replacements?
Old Apr 5, 2006 | 11:49 PM
Thorns's Avatar
Thorns
I have Metzeler(yes, this is the correct spelling) 880's on my Low Rider, and will never buy another brand of tire. Getting the same mileage out of these as the Dumlaps(On purpose). Once you try them you won't use Dumlaps again.
Thorns
Old Apr 6, 2006 | 03:44 PM
billnourse's Avatar
billnourse
I have always replaced my tires with what came on the bike. I have run the Dunlop factory tires for many years without problem or incident. I get good to excellent mileage out of them, and their handling caracteristics have never been an issue with my kind of riding.
Regards,
Bill
Old Apr 6, 2006 | 04:32 PM
SC_Compact's Avatar
SC_Compact
I just replaced by back tire with the same original OEM. They handle well enough in the wet and dry and I got over 14,000 miles from the back tire and the front is still going strong.
Old Apr 6, 2006 | 05:00 PM
LOWTOW's Avatar
LOWTOW
I have switched to Metzeler 880 also. 04FXDLI
ORIGINAL: Thorns
Thorns
Old Apr 9, 2006 | 12:51 AM
cyfxdwg's Avatar
cyfxdwg
6th Gear
What RudeDog said.....Add another vote for the Avon Roadrunners front and rear. On the Wide Glide I use a 90/90-21 Avon instead of the factory MH90-21 size. It's a tight fit with the fender but the handling is better.
