Brake Fluid Issue
Old Oct 26, 2008 | 02:43 PM
vet767's Avatar
vet767
Default Brake Fluid Issue
Bought an 03 FXDL about a month ago. Front brake M/C site glass was fogged/frosted so i could not rely on it for fluid level. Bought a new cover. When installing I saw that the brake fluid was at the proper level but was amber in color. manual says the fluid is DOT 5 which I know from experience is purple, (put buckhorns on my xlh and had to changes line, fill and bleed) Apparantly someone put in the wrong fluid at some point. Thinking I should, drain, flush, refill with DOT 5 and bleed. If I am correct, what should I use to flush the system?
Old Oct 26, 2008 | 05:47 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Believe it or not, Dot 5 will turn an amber color when old, go to a motorcycle shop that sells Dot 5 cheaper than HD. Flush with the new fluid until purple is bled out of the caliper bleeder. Might as well do your rear brakes while you are at it but beware the two screws for the cover on the rear m/c are a bugger to get off.
Old Oct 26, 2008 | 07:20 PM
vet767's Avatar
vet767
Didn't know that. Got plenty of the purple on hand already. Thanks BTW noticed the "tailhook plumber" thing. Anything to do with the gear?
nskitts
Wheels/Tires
16
Oct 3, 2021 08:11 AM
jeffrob07
EVO
25
Jun 5, 2017 07:36 PM
06Sporty75
Feb 15, 2012 07:25 AM
fiscomi
Jul 21, 2010 08:08 AM
rlchristensenmd
Wheels/Tires
Sep 14, 2009 03:05 PM
