Derby Cover Removal Saga continues.......
Old Oct 30, 2008 | 08:27 PM
carlo's Avatar
carlo
Originally Posted by skiahh
I used a T27 from the get go, but apparently the tool at the factory was set to gorilla torque and I stripped 3 out of 4 with the right tool!!
I used a combination of steps #1 and a hand impact driver. Took some really good whacks to get it started, too.
+111 on the hand impact driver try the t27 or see if a t30 will fit
Old Oct 30, 2008 | 09:09 PM
keirmc's Avatar
keirmc
what is an "easy out?" Not familiar with that term.
keir
Old Oct 30, 2008 | 09:49 PM
otterbob's Avatar
otterbob
keir
Its a hardened bit with spiraled teeth to extract broken bolts. You must drill a pilot hole first.
Left handed drill bits work pretty slick also.
Old Oct 30, 2008 | 10:01 PM
Low_Wider's Avatar
Low_Wider
Default Easy Out
Keir,
Here's a link to some different types. Basically, it's a left handed drill bit designed to grab the bolt and turn it counter-clockwise with it.
http://www.toolprice.com/category/screwextractors/
Old Oct 30, 2008 | 10:34 PM
rayfinseats's Avatar
rayfinseats
In the old days we would use a small sharp chisel and carefully tap on the left side of the bolt lead till it loosens up. (It worked on mine) I like the dremmel slotting idea also. If you drill the head off it will probably screw right out with a vice grips after the cover is removed. Easy outs (screw extractors) work best on large rusted bolts and sometimes they snap off too. I wouldn't waste my time with them on small cosmetic bolts like that.
Old Oct 31, 2008 | 05:17 AM
sporty2003's Avatar
sporty2003
best thing to do most of the time on alot of torx or allen head screw's is to tap on them.before you try to loosen them up.that seem's to help alot i think they are made of the cheapest metal known to man.
Old Oct 31, 2008 | 08:09 AM
xmarine's Avatar
xmarine
4. light the bike on fire call the insurance man...
Good idea JOE, but there is #5!
Watch tv for Billy Mays Mighty Putty!
Buy Mighty Putty. Open package and discard Mighty Putty.
Light package on fire and use as kindling for option #4 above.
J/K
I have used the Dremil to slot the fasteners, and then used a dull
chisel to loosen them.
xmarine
Old Oct 31, 2008 | 08:33 AM
Not E'nuff Harley's Avatar
Not E'nuff Harley
J/K
xmarine
Big +1 on the mighty putty! LOL!
Old Oct 31, 2008 | 02:09 PM
tribalfxr's Avatar
tribalfxr
Holy she-ite!!! That supporter pic is hilarious!!
Oh yeah, and easy-outs can suck my *****. I have never used one that didn't break on me, and drilling those out SUCKS!!!
Old Oct 31, 2008 | 02:19 PM
JRK5892's Avatar
JRK5892
if they are breaking then you do not have them seated enough and you will need to drill a bit deaper...
glad you go them out... i also have used the chissle method... lead to my first paint job when the chissle slipped off and took out a nice chunk of the tank... thankfully is was a barn build anyway!
