removed the battery
Old Nov 12, 2008 | 09:20 AM
CRF's Avatar
CRF
Originally Posted by harleyfxdc08
Why not leave the battery in for the winter? Assuming your garage is heated. I mean it might get ripped off easier with no battery? Just some thoughts.
2008 FXDC anniversary. Build 1012 of 2000.
no can do.....I dont have a garage so I have to keep it in a friends storage locker....no power outlet for the charger and no heat so out it has to come......
Old Nov 12, 2008 | 09:57 AM
robzuc97's Avatar
robzuc97
Post Battery & Security
If anything, it may throw a trouble code which you can clear. The "proper" way to remove the power source is to turn on the ignition to disarm the system, then turn off and withing 5 seconds remove the maxi-fuse. I just got off HD-net to look up another alarm question and I ain't going back! but doesn't the siren also have a back-up battery that should be removed to prevent from draining? Could've put it in storage mode unless battery freezing was an issue.
Old Nov 12, 2008 | 10:40 AM
robzuc97's Avatar
robzuc97
There is a battery for the siren! Just found it in my notes.
Old Nov 12, 2008 | 12:36 PM
CRF's Avatar
CRF
I dont have the siren so no battery there. I just yanked the battery out - I think the security system was set when I did.....am I gonna have problems?.....crap; I miss the old days when carburators ruled the earth, life was simpler and the only security system to worry about was a big f*ckn padlock and a chain......
Old Nov 12, 2008 | 01:59 PM
robzuc97's Avatar
robzuc97
I think it will just throw a DTC which can be easily cleared.
Old Nov 12, 2008 | 03:23 PM
PigInaBlanket's Avatar
PigInaBlanket
Mine was armed when I took it out and there was no code tripped that I know of.
Old Nov 12, 2008 | 04:00 PM
Noodles's Avatar
Noodles
Nothing happens on stock bike. set the clock and go
Old Nov 12, 2008 | 05:36 PM
robzuc97's Avatar
robzuc97
HD recommended procedure "to remove the power source, turn on the ignition to disarm the system, then turn off and within 5 seconds remove the maxi-fuse... due to touching cable to terminal while hooking up up which may cause a low battery trouble code". Found out about the clock when as a prank, pulled friends maxi fuse when we were setting him up on dyno. Geez, my two doesn't even HAVE a maxi-fuse... lol
Old Nov 12, 2008 | 06:51 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If the security isn't armed at the time I don't see any harm. Pulling the power on an armed system could have some effect on the TSSM.
Old Nov 12, 2008 | 06:59 PM
Double00Aught's Avatar
Double00Aught
Originally Posted by PigInaBlanket
I replaced my battery recently and it was unplugged for an hour or so. I haven't noticed any problems after plugging it back in and I didn't reload my Power Commander map. I would have known if the map needed reloaded as it pops louder than Oprah smacking her lips at KFC when it's at the stock setting.
Man that's damn funny, I don't care who you are. Thanks for the laugh.
