Question - tool size (no data in service manual)
Old Nov 18, 2008 | 03:42 AM
roy2008's Avatar
roy2008
Default Question - tool size (no data in service manual)
Since I see no data in service manual I am asking. Can anybody advise the size of;
1. TORX screw driver for clutch inspection cover of primary chain case
2. hex wrench for transmission filler plug
Thank you for your help!
Old Nov 18, 2008 | 07:21 AM
shimmon's Avatar
shimmon
Well i think the clutch cover is a t27...
If you havent bought a nice set of torx bits, you need too.... Same goes for allen heads... Dont just get a set of allen wrenches... Get them to put on your ratchet. As for the drain plug, i think a wrench is easier!
ANOTHER TIP IS TO TAKE A SMALL PUNCH AND TAP THE BOLT HEADS ON THE INSPECTION COVER TO HELP BREAK THE LOCTITE LOOSE... THEN YOU SHOULD USE BLUE LOCTITE TO REINSTALL. OR YOU CAN HEAT THE HEAD OF THE BOLT TO LOOSEN THE LOCTITE.
Old Nov 18, 2008 | 07:28 AM
rockon's Avatar
rockon
T27 for the cover.
JONNIEROCK
Oct 2, 2015 10:36 AM
samac1068
Jan 2, 2015 03:31 PM
ZenGlide
Jul 4, 2014 02:28 PM
tmitchellof PG
Nov 17, 2007 08:40 PM
Dragon919!
Jul 3, 2007 09:47 AM
