oil levels
Old Nov 22, 2008 | 04:28 PM
ggibson's Avatar
ggibson
Cool oil levels
After some discussion on oil levels decided to check mine when cold and then hot. Level at cold indicated oil was at the hot level line...damn the dealer has overfilled it....anyway checked it hot and the level was exactly the same ie at the correct hot level line..doesnt make any sense to me... I checked it the same both times ie on sidstand and removed dipstick wiped it clean and screwed it back in as the manual states....so WTF ?
Old Nov 22, 2008 | 04:52 PM
PoCoBob's Avatar
PoCoBob
I've done the same thing. Checked it cold and then again about 15 minutes after a 4 hour ride. No difference. That check only when hot is a bunch of crap.
Old Nov 22, 2008 | 05:18 PM
Mr E's Avatar
Mr E
I'm with Blaster
Old Nov 22, 2008 | 06:54 PM
riverman's Avatar
riverman
I don't think it is hot and cold so much. I think when the bike is sitting gravity pulls oil out of the tank and down into the case. I think in order to get a good check on the level, you have to run the engine a bit to pump the oil up out of the case and into the tank. If you top the tank when there is a bunch of oil in the case, when the pump comes up to pressure the tank will be over full.
Old Nov 22, 2008 | 11:40 PM
rounder's Avatar
rounder
my oil differs.. cold it is halfway between add and full. hot it is full.
Old Nov 23, 2008 | 12:06 AM
archergodwin's Avatar
archergodwin
ya... no. Not on the Dyna. The softtail maybe. The Dyna's oil tank is under the transmission. (below the crank) Gravity won't start a syphon for you. Besides, there's not a lot of room for oil in the crankcase on the engine. It's pretty much a dry sump system - there's two scavenge lobes on the oil pump that scavenge oil from cam area and crank area. The sump in the crank area is only about 3/8" deep.
I'll continue to check my oil according to the manual. You may do as your knowledge directs you to do.
Old Nov 23, 2008 | 05:40 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I always check when very hot. The cold check shows differently but not by much. But I check it 4-5 minutes after riding.
Old Nov 23, 2008 | 07:40 AM
rocklayer2's Avatar
rocklayer2
Harley
Topspin's Avatar
Topspin
Oil level is not an exact science down to the drop. But, I'd rather have a bit less than a lot more.
Old Nov 23, 2008 | 09:22 AM
rounder's Avatar
rounder
the hot check procedure outlined in my service manual suggests after longer ride(over 20 miles) let idle for 2 minutes then check fluid. When my bike is hot but not fully hot(maybe a 5 min, ride) the oil level appears the same as cold almost.
