Lowering a Wide Glide
Old Nov 22, 2008 | 05:18 PM
MidnitEvil's Avatar
MidnitEvil
Question Lowering a Wide Glide
When I take my front end apart this winter, I am going to replace the fork springs. I plan on going with Progressives. I noticed they have springs that will lower the front end an inch or two. If I do that, I plan to replace my shocks, and drop the back end an inch as well.
If I drop the rear an inch, is it just a matter of swapping the shocks out, or will I need to do other mods to deal with reduced fender clearance or anything else?
Old Nov 22, 2008 | 06:48 PM
jmpancoast's Avatar
jmpancoast
Check wiring under fender to make sure it is tucked well since it will be closer to the tire.
Secondly, check belt tention.
Old Nov 22, 2008 | 07:00 PM
Romark's Avatar
Romark
I just changed my shocks and all is well. I went with the Progressive 440's and they are fantastic.
Old Nov 22, 2008 | 07:01 PM
Romark's Avatar
Romark
If you lower the front and rear (I only did the rear) you might want to double check your jiffy stand length. It may be too long. IE: make the bike stand up too straight.
Old Nov 22, 2008 | 10:57 PM
rounder's Avatar
rounder
stock length for your wideglide is 12.6" going to an 11.5" should be fine clearance wise. If you go to an 11" shock you could run into problems with your belt guard hitting the fender. Progressive warns of this specifically for the wideglide. They include a warning paper and diagram showing where you will need to cut the rear fender to avoid this.
The progressive kit for lowering the front requires that the fork legs be disassembled. Plan on taking the lowers off the downtubes to install the included springs that lower forks either 1"or 2".
Old Nov 23, 2008 | 12:14 AM
MidnitEvil's Avatar
MidnitEvil
I'm putting chrome lowers on this winter, so I figured I may as well swap out the stock springs while I have everything apart. I keep seeing the reference to 1" or 2"... that's even what Progressive says. So, which is it? Is it a choice I get to make when installing them?
Old Nov 23, 2008 | 12:20 AM
rounder's Avatar
rounder
the kit includes 2 smaller springs. Each spring represents an inch of lowering. Install both to get 2" or one for 1". The springs install in the fork lower. Also included is a pvc like spacer that you cut to set your preload.
Old Nov 23, 2008 | 12:50 AM
traveler's Avatar
traveler
2" is too much! Since you ride 2 up, you don't want anything shorter than an 11.5 shock in the rear. That's 1 inch lower. You can leave the front end stock height and still lower the rear and be fine if you wish. What makes a big difference is fork oil. Thicker oil keeps the forks from being "spongy". Screamin Eagle Fork oil has a pretty good rep. If you find your jiffy stand is keeping the bike too upright, you can get a 1" under stock style jiffy stand through j&p cycles for around 100 bucks. I have one and it works fine on my bike....granted I ride solo, and use 11" Progressives in the rear, and raked out the front to level the bike out.
~Joe
Old Nov 23, 2008 | 07:51 AM
wescoot2's Avatar
wescoot2
I lowered my front end with prgressives 1 in. and put a set of 11.5 in 440's on the rear with no problems on my 01 Wide Glide. Didn't change out the stand, although I will say when parking on some slopes it does become tricky.
Respects,
Ed
Old Nov 23, 2008 | 10:45 AM
chad peterson's Avatar
chad peterson
Mine is set up like yours wescoot2. 440's in rear, and 1" up front with progressive springs. No problem with stand sittin bike too straight, but same as you, it's sometimes different on slopes (no big deal). I love this set up, rides killer!
