Anybody know?
Old Nov 26, 2008 | 11:06 PM
wmo777's Avatar
wmo777
Post Anybody know?
Hey there
Does anyone know the interior diameter of the end of the drag bars on a Fat Bob? I'm interested in putting bar-end mirrors on, but need to know if they are larger than 22mm on the inside. Also if you know where I can get rubber plugs for the existing mirror holes, that would be great.
I've been reading this forum for more than a year, and you guys really help out with all your info.
Thanks
wmo777
2008 Vivid Black Fat Bob
Stage 1, SE slipons,
Kury Extended forward controls
and more
Old Nov 26, 2008 | 11:14 PM
Lorance66's Avatar
Lorance66
I will be installing some new grips soon (hopefully) and I can measure when I do that, but until then I am afraid I can't be of much help. I will try to remember to look for this thread when I get around to doing the grips and see if you still need an answer.
Old Nov 27, 2008 | 03:28 PM
wmo777's Avatar
wmo777
Lorance66,
That's cool, I am in no hurry. Have a happy turkey day!
Old Nov 27, 2008 | 07:47 PM
wkdavistx's Avatar
wkdavistx
Just take your left grip off and measure it. It is only held on by the switch housings clamping around it and maybe a little glue (which you don't need).
Old Nov 28, 2008 | 09:39 AM
08fxdf43202's Avatar
08fxdf43202
I replaced the stock grips on my Fat Bob the first day I had it.
The bars are the same diameter at the hand grip area as all other 1" Harley bars. The diameter of the stock drag bar at the clamp area is 1 1/4"
To remove the stock grips, I used a razor knife to slice both left and right grips length ways and peeled em off with out any dis-assembly of the hand controlls. The throttle side stock grip is lightly glued to a throttle sleeve. If you want or need to remove the sleeve then dis-assembly of the hand controll would be required.
tbonetony06
May 2, 2013 09:23 AM
Fta Boy
Mar 13, 2013 08:08 AM
BlackhawkDriver
Aug 5, 2011 12:07 AM
pelliott6
Jul 7, 2009 06:12 PM
Regmon
General Topics/Tech Tips
Jun 16, 2009 08:57 PM
