Another Tank Raise Question...
Old Dec 2, 2008 | 01:55 PM
Mascman's Avatar
Mascman
I would suggest disconnecting the fuel line at the quick-disconnect before moving the tank.
I learned the hard way that if you lift the tank too high during installation, the other end of the fuel line is plastic and solid mounted...it can crack.
My crossover line was rubbing on the frame so I used a piece of hose, split down the middle as protection.
Old Dec 3, 2008 | 03:47 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Starting to get my brain wrapped around this mod as a winter project. I was wondering, does the mod raise just the front end of the tank (steeper tank angle), or 2" at the front AND rear? If the former, does it throw off the accuracy of the fuel gauge (as if there's any to begin with!) or affect "usable" fuel quantity? If the latter, are there any interference problems with the front of the seat? Thanks.
Old Dec 3, 2008 | 08:08 AM
2007fxdc's Avatar
2007fxdc
Gonna be a long winter if this is your project. You can do this mod in about a half hour with simple tools. It's just a bracket that raises the front of your tank. It doesn't affect how many miles you can get out of a tank, which is what you should be going by anyway, but it may change how your gauge reads. For me, it made mine way more accurate as it was way off from day 1 to begin with.
pointdogg48
Sportster Parts
Jan 30, 2012 04:42 PM
gbneal
Nov 4, 2011 03:26 PM
TX_Mason
Mar 12, 2011 01:40 PM
timberwolfz28
Aug 17, 2008 09:20 PM
dope_man_21
Screamin Eagle CVO Models
Apr 13, 2008 01:47 PM
