Another Tank Raise Question...
Old Nov 30, 2008 | 11:09 PM
RiverWolf's Avatar
RiverWolf
Default Another Tank Raise Question...
I have read a ton of posts...
Looked at a lot of pics...
Spent time on search...
Just can't seem to find out how to order the 2" tank lift for my 2008 Streetbob?
Any help here is thanked in advance.
Old Nov 30, 2008 | 11:12 PM
ackman1968's Avatar
ackman1968
Jackyl is the man you need to talk to. Look him up in the member directory and send him a PM.
Old Nov 30, 2008 | 11:18 PM
trip20's Avatar
trip20
He sells them on eBay
Old Dec 1, 2008 | 04:23 AM
jackyl's Avatar
jackyl
P.M. with info sent. jackyl
Old Dec 1, 2008 | 05:10 AM
Harley43147's Avatar
Harley43147
Riverwolf.
I have a Jackyl 2" lift on my 08 Bob.
The quality is excellent and I'm sure you'll be pleased with the results.
Old Dec 1, 2008 | 09:00 AM
jbphoto's Avatar
jbphoto
Originally Posted by Harley43147
Riverwolf.
+1 for Jackyls 2" tank lift.
Here's a couple of installation hints. After you get the lift wait until you're ready to get gas before you do the install. It will make the job just a bit easier as you won't have the extra weight to contend with. Take the bolt and acorn nut from the rear of the tank and use it up front. Use the one Jackyl supplies on the back of the tank. Makes for a better looking installation with both acorns up front. Also, on my Bob the stock vent hose leading from the tank to the junction at the side of the frame was too short after the lift was installed so I had to use the extra piece of fuel line (which is supposed to be used as a replacement crossover line in some installations) to replace it. Other than that the install was a snap. Great product and exceptionally well made. You'll like the look!! By the way, my sig pic was taken prior to the lift install.
Old Dec 1, 2008 | 09:14 PM
Evil Stepdad's Avatar
Evil Stepdad
+1 for what JBPhoto said, including the vent hose being too short. Since I didn't need to replace the crossover line, I just used the extra tubing for the vent hose.
Old Dec 1, 2008 | 11:06 PM
MZBuckeye's Avatar
MZBuckeye
I gotta get this, it's first on the list for winter upgrades.
Old Dec 2, 2008 | 01:40 AM
ggibson's Avatar
ggibson
Default 2" lift
Hey Jackyl, was wondering why a 1" lift is not available. What are the interference issues ?
Old Dec 2, 2008 | 09:28 AM
2007fxdc's Avatar
2007fxdc
+1 on the acorn nut, although I just swapped the nuts if I remember correctly, the bolts are the same or similar enough, aren't they? Jackyl had mentioned something a while back about including this in his install instructions but I don't know if he did it or not. As for the crossover, mine was okay. It contacts the frame now but I keep an eye on it and it doesn't appear to be wearing any and still works just fine.
