Bearing size on a 2005 superglide?
Old Dec 7, 2008 | 11:21 PM
anubisss's Avatar
anubisss
Default Bearing size on a 2005 superglide?
Can you swap a stock superglide rear to a stock fatboy wheel? Are the bearings and axle the same size? I figure you Dyna guys will know. Thanks.
Old Dec 8, 2008 | 05:45 AM
dyna rider's Avatar
dyna rider
Default Bearing Size
I'm no expert but I am pretty sure the axle and bearings are 3/4" on the 05. You cannot put a fatboy rim on a 05 or any other dyna without some mods. The center hub is wider than on a stock wheel.
Old Dec 8, 2008 | 09:21 AM
JayFromPa's Avatar
JayFromPa
3/4" axle on that year.
The sprocket is different to, it will be a more narrow belt.
Not sure about the hub.
Old Dec 8, 2008 | 09:47 AM
anubisss's Avatar
anubisss
Thanks guys.
Old Dec 8, 2008 | 09:49 AM
xxxflhrci's Avatar
xxxflhrci
A '00-'05 Dyna wheel will bolt right on a '00-'02 Softail.....Got the info from the back of a HD catalog....Look for yourself.
At any rate, 1" or 3/4" bearings are no problem if you need one or the other. They can easily be swapped.
Old Dec 8, 2008 | 10:02 AM
glide05's Avatar
glide05
stock front axle is 1" on 2005, not sure about the rear.
Old Dec 8, 2008 | 10:04 AM
rounder's Avatar
rounder
the older fatboy wheel and nighttrain wheel fit up perfectly.... see my sig below.
that rear wheel is the part # to an 03 night train. the new wheel with the 200 tire will not fit.
So anubisss depends on the year of the wheel.
Old Dec 8, 2008 | 10:06 AM
imjdoggie's Avatar
imjdoggie
They are 3/4" and like xxx said it is not a problem to swap them.
Old Dec 8, 2008 | 11:23 PM
fixxr's Avatar
fixxr
FYI late sportster rear wheels(06,07)will also go on with a bearing change.Thats what I'm running right now.
Old Dec 8, 2008 | 11:28 PM
xxxflhrci's Avatar
xxxflhrci
I've got a Sporty wheel outback, too. I lucked up and found a model year that didn't need a bearing change.
Attached Thumbnails Bearing size on a 2005 superglide?-mag-wheel.jpg   Bearing size on a 2005 superglide?-whitewall.jpg
jonny lu
May 25, 2013 09:24 PM
Miguelpoire@yahoo.com
Feb 3, 2012 03:32 AM
drumguy460
Jul 24, 2011 08:57 PM
Naz_Man
Nov 11, 2006 10:37 PM
GeorgeJ
Aug 16, 2006 08:43 PM
