'08 FXDC Shock length
Old Dec 19, 2008 | 06:10 PM
Double00Aught's Avatar
Double00Aught
Default '08 FXDC Shock length
Been looking over my service and owners manual trying to confirm the shock length. I think it is 12.6" but not positive. Looking at replacing the stock with a set of 412's of the same length.
Old Dec 19, 2008 | 06:13 PM
Gwjvw's Avatar
Gwjvw
They are 12.6
Old Dec 19, 2008 | 06:17 PM
Double00Aught
10-4, that's what I was thinking, just wanted confirmation. Thanks
Old Dec 19, 2008 | 08:26 PM
SuperFastGlide's Avatar
SuperFastGlide
go lower
Old Dec 19, 2008 | 08:35 PM
Double00Aught
I'm considering that. I'm one of the believers that a lot of time and engineering has went into the proper measurements of the suspension system. Albiet, I love the way a lowered rear looks. Any suggestions on what shock length works and looks best?
Old Dec 19, 2008 | 08:43 PM
Gwjvw's Avatar
Gwjvw
If you want to stay close to hd style go with some 12in,i have 11 1/2 and have been thinking about 11in.
Old Dec 19, 2008 | 09:41 PM
rounder's Avatar
rounder
all dynas have the same frames... 3 out of 5 models have 12" shocks...the old fxdx had 13 or 13.5. By decreasing the length of the shock you only effect height and length of travel. The angles of travel remain the same so the simple single pivot suspension will continue to move in the same arc.
Old Dec 19, 2008 | 09:45 PM
rdondes's Avatar
rdondes
You will also lose lean some lean angle. Meaning, your pegs will hit sooner in hard cornering. There are advantages (looking cooler) and disadvantages (lose some handling) to everything.
Old Dec 19, 2008 | 10:10 PM
Double00Aught
That's a pretty good explanation. I may look into lowering a little.
Chaos09
May 5, 2017 05:26 PM
Griff012FLHX
Nov 22, 2011 05:29 PM
fathertime
Nov 2, 2008 09:10 PM
Billiam92407
Oct 5, 2007 11:24 AM
ftlee20723
Sep 28, 2007 12:09 PM
