carb and FI have the same part# for their tanks. They are completely interchangable!....the only difference between a streetbob tank and a lowrider one is the dash.... Same part #for the tank. any 04-current one will work....same part#.
I think the 04 - 09 fuel injected Low Rider and 06 - 09 Street Bob tanks are the same. Please verify this before you buy anything. The consoles on these models are interchangable. For example, you can buy a Street Bob tank, use your speedo, then buy the Low Rider console, tach, and mounting components. This will bolt up to your bike and give you the speedo and tach on the tank.
Start stretching your arms cause you will probably have to dig in your pcokets pretty deep to do all this.
I'm slow so don't mind me lol!
Are you saying that any dyna tank from 04 to now will mount up to my bike?
The way I understand the Wgs will not fit!
Correct me if I'm wrong please!
Donnie
yeah any 04+ lowrider or 06+ streetbob is the same tank. The console is different because the lowrider has the tach. A streetbob owner can buy a tach. and lowrider console and mounting plate and install it on his current tank if he wanted to.
Also to keep your chrome look... the 08 SE dyna console is just a chrome version of the streetbob one. this way you do not need a tach.
The wideglide tanks will bolt right up to your frame as well(any04+). with the wideglide ones you will have the 5" speedo to add (or do like that guy on your website did with his 4" speedo and get an adapter). Also you have the ignition switch on the dash to think about.
So find a good deal on any 04+ dyna tank and then choose the console and mounting you want and install.
I researched the heck out of this a few months ago...
Just becareful how much you pay for a used tank and check around for prices to get it fixed(if damaged) and painted before buying.
You can get a new street bob tank in vivid black for about $650 new for reference.
Like others said the street bob, low rider, 08 Se dyna dashes will all work with you speedo, just need different plates. The 08 SE dash is nice but costs over $200 and it also has the ignition in the dash.
Tank in your pic is from the 07 SE and it uses the handle set up in my signature.
