Question about RPMs
Old Dec 28, 2008 | 04:17 PM
  #31
bberck's Avatar
bberck
Originally Posted by Gary7
Now that's what I call "hard evidence."
I'd say that 60 in 5th is definitely around 2500 rpm based on what you're seeing at 70. Do you remember if that's what it was?
Think it was more like 2400
Old Dec 28, 2008 | 04:19 PM
  #32
Gary7's Avatar
Gary7
That is strange. My engine was turning over slower than I thought on my way home yesterday. Amazing how low-end torque can fool you.
Old Dec 28, 2008 | 08:50 PM
  #33
archergodwin's Avatar
archergodwin
Originally Posted by Pepsimayn
I've always wondered what "long distance/steady RPM" is by definition. I want to get to the 1000 mile service as quickly as possible (within 2 weeks) because I've got a longgggg drive from MI to NC.
Is there a general rule of thumb for highway miles during break in?
Vary your speed - don't keep it at one steady rpm/speed.... change gears, speed up, slow down... not all real quick mind you.... but every few miles.
Old Dec 29, 2008 | 02:01 AM
  #34
TOMMAY's Avatar
TOMMAY
70 in 6th should be about 2500 rpm.
Maybe my 06 is geared differently from the later models. Checked tonite on a ride over to the eastern shore. At 3000 rpm I'm at 72 mph,70 mph is about 2900 rpm. I'm running a 180 tire, the profile may be a little lower,guess that could make a tad of difference.
Anyway,my bike is happy.
Good Luck
Tom
Old Dec 29, 2008 | 02:09 AM
  #35
Mastertone's Avatar
Mastertone
6th Gear
Default gearing...
It could be set up to get the "outlaws" out of more tickets. Radar is radar, and there's no way a county mountie will not be taking pictures when you go by. But the sound of a modern twin cam running 90+ sounds milder than a 30 year old harley running 40. With that in mind, the modern day engines should rack up some impressive mileage and lifespans. Every bike has that sweet spot, for some of the "outlaw" types, it's alot faster than I'll ever like to run.
Old Dec 29, 2008 | 06:59 AM
  #36
Gary7's Avatar
Gary7
Seems like I remember reading somewhere that the 06s with the TC88 are geared quite a bit lower than the 07-09 bikes with the TC96. That would account for your higher rpms.
Old Dec 29, 2008 | 07:55 AM
  #37
mud's Avatar
mud
Good Luck
Tom
Tom, I've posted this a few times.
Yes our 06s have more desirable, in my opinion, gearing..........
......rear sprocket......
.............the 006 domestic is 70 tooth.
.......the 007 up domestic is
66 tooth
.....the 006 international is 68 tooth.
.....the 007 international is 64 tooth.
....gear........006.......
007 and up....005 back
....1st.......9.876......
9.312......10.11.......1st
....2nd.......6.81.......
6.421.......6.958......2nd
....3rd.......5.064......
4.774.......4.953......3rd
....4th.......4.164......
3.926.......3.862......4th
....5th.......3.477......
3.279.......3.15........5th
....6th.......2.96........
2.79.......no
.........drive belt for 006 domestic is 133 teeth
.........drive belt for 007 domestic is
131 teeth
..drive belt for 006 international is 132 teeth
international is 130 teeth
edited to add.....
difference in the 06 and the 07 up is
in the rear sprocket, not the transmission
Old Dec 29, 2008 | 06:25 PM
  #38
mud's Avatar
mud
Ya I went back out to make sure I wasnt crazy lol
It runs about 2500 at 70 in 6th gear.
Here is a pic of 70 in 5th. Looks like closer to 2900
bb, checked my 006 today.
5th gear.....60 mph.....2800 rpm
5th gear.....70 mph.....3200 rpm
6th gear.....70 mph.....2800 rpm
gearing
Old Dec 29, 2008 | 06:29 PM
  #39
bberck's Avatar
bberck
gearing
Well it looks like my tach works right then, with the different sprockets between the 06 and 08. I was a little worried about my tach, with the issue I had with it when I first put it on.
Old Dec 29, 2008 | 06:58 PM
  #40
domenicp7's Avatar
domenicp7
Great info guys.
