Triple tree marker lights
Old Jan 3, 2009 | 10:37 PM
Mr. Lucky's Avatar
Mr. Lucky
Originally Posted by kenfm2000
Has anyone used these type of marker lights on a Dyna? If so do you know if they are single or dual element?
I have them on my Night Train (which has a Wide Glide front end). They are single filament, single wire. They use the mounting bolt as the ground return.
Old Jan 4, 2009 | 11:59 AM
kenfm2000's Avatar
kenfm2000
Originally Posted by Baeseman1
Not sure about good looking, but I have a set of those...
I'm going to say they are dual element. When the bike is on, they act as running lights. I don't think you normally do that with a single element.
Thanks for posting the pic. That is exactly what I wanted to see. Mr.Lucky said his only has a single wire. Is yours working as blinkers and running lights all on just a single wire. I guess I am mentally challenged enough to not understand how that would work. I'm not sure I will go this route since I planned to get a toolbag to put right in that location, but I do like the profile of that setup.
Thanks to everyone else who chimed in as well.
Old Jan 4, 2009 | 12:03 PM
fame2's Avatar
fame2
you can also check out www.customdynamics.com. they have a few options for light bars and turn signal replacements.
Old Jan 4, 2009 | 12:08 PM
RenoRider's Avatar
RenoRider
Default Pro One triple tree light
I see all you Dyna folks that have that set up and I really like it. I have one on order and I am going to try to mount under the head light at the tree on my street glide.
I have not seen a bager with that set up and I think it would really clean up the front end and get rid of the stock turn signals.
Old Jan 4, 2009 | 12:34 PM
Streets of Fire's Avatar
Streets of Fire
Here is the link I mentioned last night that Joe put on YouTube of his bike with led turn signals.
http://www.youtube.com/watch?v=gEa1qPAVEkw
Old Jan 4, 2009 | 03:31 PM
Baeseman1's Avatar
Baeseman1
There is a single wire per side (left & right). I had a brain fart when I said dual element - only 1 wire per side. And yes, they are running lights in addition to directionals.
Did you consider placing the tool bag down low? Right under the voltage regulator? Just a thought...
Old Jan 4, 2009 | 06:36 PM
dpriest's Avatar
dpriest
yeah joe made those himself from what I remember on another post. those are not the pro one lights.
Old Jan 4, 2009 | 06:38 PM
dpriest's Avatar
dpriest
Thats cause theres nothin clean on a bagger.lol
Old Jan 4, 2009 | 08:54 PM
Mr. Lucky's Avatar
Mr. Lucky
They only act as running lights if you have something like the Kuryakin run-turn-brake module installed. Mine do not function as running lights.
kryingame
May 31, 2022 07:54 AM
slyedog
Oct 15, 2014 10:29 PM
JaronB
Feb 2, 2009 05:51 PM
MikesWideGlide98
Mar 10, 2008 01:55 PM
JRK5892
Jun 8, 2007 07:48 PM
