Fat Bob with mini tachometer
Old Jan 13, 2009 | 02:39 PM
ElusiveThorn's Avatar
ElusiveThorn
Default Fat Bob with mini tachometer
Anyone install a mini tachometer on the FXDF? I can see one on the CVO but I would like to see a picture of a mini on a FXDF.
Thanks~
Old Jan 13, 2009 | 06:13 PM
luckyB's Avatar
luckyB
Try the search... couple forum members have done this...
https://www.hdforums.com/forum/dyna-...-a-fatbob.html
https://www.hdforums.com/forum/3875525-post9.html
Old Jan 13, 2009 | 09:46 PM
ElusiveThorn
Thanks lucky. I did search but didn't come across that thread.
Old Jan 14, 2009 | 09:08 PM
doxbike's Avatar
doxbike
Thanks~
Got one ordered-won't ship for 3-5 days, tho'
Old Feb 8, 2009 | 08:57 AM
doxbike's Avatar
doxbike
Default MiniTach from Speedway instruments
Forgot to post the pix.
Install pretty straightforward, but make sure you've got good light to see the wire colors so you get the right bundle to splice into.
Works great
Attached Thumbnails Fat Bob with mini tachometer-fatbob-at-the-beach-005-wince-.jpg
Old Feb 8, 2009 | 09:22 AM
AdrianVall's Avatar
AdrianVall
doxbike: Is that tach from speedway instruments?
Old Feb 8, 2009 | 09:25 AM
MZBuckeye's Avatar
MZBuckeye
I think so. I've got that on my wish list. I plan to stick it to the front brake master cylinder.
Old Feb 8, 2009 | 11:29 AM
BluBob's Avatar
BluBob
You can also fab a small L bracket and mount it off of your tank bolt. Pretty easy to hook up with the piggy back connectors in the kit.
Attached Thumbnails Fat Bob with mini tachometer-img_0001.jpg   Fat Bob with mini tachometer-microtach-riders-view.jpg
Old Feb 8, 2009 | 12:11 PM
AdrianVall's Avatar
AdrianVall
BluBob: That looks really clean man.. great job with that. I think I may go that route when I do get that. Thanks for sharing!
Old Feb 9, 2009 | 01:13 PM
BluBob's Avatar
BluBob
Thanks, it was pretty straightforward. I didn't want to mess with internally wiring the tach from the master cylinder, and didn't have enough flat area on the tree between the risers, so that seemed like a good spot. I was tempted to stick it on or in the dash, but didn't want to cut in case I didn't like the results. I fabbed the bracket out of my leftover stock air cleaner. Just cut a small plate out of the edge and bend it to an L.
