06 Street Bob - Will not start
When I turn the key on I no longer hear the whirring noise from the gas tank (fuel pump I guess?). Is this a good indicator that the pump is bad since it seems to not be picking up any fuel to continue running when priming the cylinders and I dont hear that whirring noise?
Looking for any help at all, cuz I want to get her back out on the road. Oh, and if it IS the pump, does anyone have a part number or anything, or where I could order this from online (Im sure HD dealer is gonna be costly).
1. Top one with a 40 is main fuse (maxi-fuse)
2. left big one is starter relay
3. next one is system relay
NEXT row of small ones: (from the left)
1. top one: ecm fuse
2. middles one: fuel pump fuse (check this one)
3 lower one: engine control fuse
SECOND row of small ones from left:
1. top one: spare (swap this one with the fuel pump fuse)
2. Middle: spare
3. lower one: customer accesssory fuse
THIRD row of small ones from left
1. top one: open
2. middle: battery fuse
3. lower one: accessories fuse
LAST row of small ones from left
1. top one: instruments fuse
2. middle one: ignition fuse
3. lower one: lights fuse
Hope this helps. Check your battery cable connections as well. And it wouldn't hurt to put the battery on the tender and give it a full charge as well.
The steps for replacing the pump are very specific and the manuals give you an exploded view of the assembly.
After pulling the tank apart and getting the fuel pump assembly and gas gauge float mechanism out, I saw that I had a lot of corrosion on the pump, float, underside of top plate, and even IN the tank (under the gas). My father, who was helping me with this, asked if I had ever used a gas can from the shed and I told him I did. He tells me it was a can of bad gas that he had go missing a while back and didnt know what had happened to it.
So I ordered a new pump assembly (all of it) for $280 shipped to the house, but now I am contemplating replacing the top plate and float assembly as well.
Concerning the tank, is there any way of removing this rust like corrosion (it's spotted on the sides of the tank and at the bottom of the tank) without having to cram my big hand into a small hole and MAYBE wipe most of it off? I know pictures will help and I will try to get some on Monday as I will be working all day today.
Also, I was talking with some of the guys here at work and they mentioned there is some kind of fuel tank cleaner that would help clean the inside of the tank of the deposits. Would anyone know of, or be able to recommend, what sort of cleaner I would need?
