SEII with BCT Baffles Video Clip
Old May 5, 2006 | 03:56 AM
Original Junior's Avatar
Original Junior
From: The birthplace of our nation- Philadelphia proud!
Default RE: SEII with BCT Baffles Video Clip
What's everyone's experience with the BCT baffles so far? If I understand this correctly, I don't need another download since I got the HD download with the SEII's and SE A/C when I took delivery? Is this correct? I've been waiting for some black Bassani Pro Streets from a dealer for over a month. I'm ready to cancel the order and go with these if I don't need another download. I'm tired of waiting. Thanks.
Old May 5, 2006 | 09:33 AM
Angry_Monkey's Avatar
Angry_Monkey
Mine should be in today, I'll try and report back. We should of talked to them about working a discount..
Old May 5, 2006 | 09:38 AM
Rhode Warrior's Avatar
Rhode Warrior
Sounds great. Must really sound good at full throttle. Potato potato.
Old May 5, 2006 | 11:49 AM
WgSkee's Avatar
WgSkee
Has anybody tried this..?
"The slip-ons have a baffle in them. The baffle is held in the slip-on by a bolt through a hole in the slip-on and into a weld nut in the baffle. Remove the bolt and slide the baffle out of the slip-on(they can be stuck sometimes). You will see how the baffle is constructed which has an angle diverter in the middle of the baffle. Take a big screw driver and bend the diverter so it allows more exhaust through the baffle. Do both baffles the same. Reinstall the baffles. Depending how big of an opening you made(I opened mine about an additional 3/8" more), you will have more sound, and the mid-range will be more alive, and you won't feel any difference in the bottom rpm's. The "Harley" sound will be talking to you. I also had a DFO, so I could adjust for any popping on decel. The fun($$) never stops with a Harley.
Thorns"
Old May 5, 2006 | 10:00 PM
jw5150's Avatar
jw5150
Got my BCT baffles and just went for the first ride. Great sound and I noticed a little more low end. Rode out to the dealer and everyone agreed the baffles made a big difference in sound. I am happy with my choice.
Old May 6, 2006 | 04:01 AM
kaduku's Avatar
kaduku
ORIGINAL: jw5150
Give them a fews day and they seem to get even better!
Old May 7, 2006 | 01:39 AM
NikoNY's Avatar
NikoNY
Sorry for a rookie question, but is re-jetting necessary?
Old May 7, 2006 | 01:55 AM
kaduku's Avatar
kaduku
ORIGINAL: NikoNY
I had the Stage 1 AC and download prior to changing to the BCTs. BCT claims that is you've already have the download that it should be fine. So far, my bike runs great, though I do have occasional backfires. I can deal with that and will never go back to original baffles. I plan to go SERT or PCIII in the future, which should correct everything.
Sounds like you have a carb system, if so, you may want to contact BCT first!
Old May 9, 2006 | 01:11 PM
Whiffleboy's Avatar
Whiffleboy
OK guys, I'm still considering picking up a pair. Those who've installed them and haven't chimed in yet, let's hear what you think. Is there a $130 difference in sound? Should I pull the trigger?
Whiff
Old May 9, 2006 | 07:25 PM
Angry_Monkey
whiff,
Put them in last week, haven't been able to ride since, I'll let you know tomorrow. I'll tell you it made a big difference just idling though.
My only concern is that they'll be tooo loud.
