Dyna Rear Axle Alignment
Old Feb 6, 2009 | 08:57 PM
DJM's Avatar
DJM
Stage III
Default Dyna Rear Axle Alignment
Can someone give me the part number for H-D Axle Alignment Plug set for the newer hollow rear axle. Thanks
Old Feb 6, 2009 | 09:00 PM
speedjunkie's Avatar
speedjunkie
Huh? There should be a hole in the swing arm 2-3 inches forward of the axle head/nut. That's where you take your measurement from. Use a bent and sharpened piece of rod, like a coat hanger. Or use a caliper and measure to the center of the axle, both ends. Cheap and easy.
Mike
Old Feb 6, 2009 | 09:10 PM
INTHERED's Avatar
INTHERED
I had the part number a while back but when I tried to order them from my local HD dealer they could not find them on their computer and suggested that they were not for sale to the general public. The part number is listed in the 08 service manual I'll see if I can borrow my buddy's manual again and post the number here on the forum.
Inthered
Old Feb 20, 2009 | 03:10 PM
INTHERED's Avatar
INTHERED
Here is the part number for the axle alignment plug kit = HD48856
Inthered
Old Feb 20, 2009 | 03:31 PM
r00k's Avatar
r00k
made mine out of a bicycle spoke and a left over drain plug gasket. $1.50 and it works better.
Old Feb 20, 2009 | 03:51 PM
r00k's Avatar
r00k
This is the tool I made.
Old Feb 20, 2009 | 04:28 PM
jackyl's Avatar
jackyl
here is a alignment tool. jackyl
http://cgi.ebay.com/ebaymotors/REAR-...Q5fAccessories
Old Feb 20, 2009 | 04:33 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Mine looks more like R00k's, except I have a zip tie instead of an Oring.
Old Feb 20, 2009 | 05:45 PM
mud's Avatar
mud
Don't have a part #..... the *tool* can be made in minutes for pennies.......
Old Feb 20, 2009 | 07:50 PM
INTHERED's Avatar
INTHERED
I believe the later model dynas have larger holes in their axles which when using your tool would tend make the alignment more like guess work. It would really be nice if the axle had the same size hole in it as the swingarm.
inthered
