That would make sense if we were talking about a sophisticated FI system with OBDII but we're not. He's got an '04. No oxygen sensors. The computer doesn't know **** about air/fuel ratio besides what you tell it, hence the need for a piggyback module. If the bike is running lean, the plugs will still tell the tale, fuel injected or not.
79lowrider, if your bike is running rich then you have the only fuel injected harley in existence that ever rolled off the assembly line while the EPA guys were on a coffee break.
If the older FI bikes are open loop systems, then that is correct.
ok look guys its running rich! The plugs show it and so does the throttle body the butterfly is caked with soot also when i let off the throttle from normal riding like to come to a stop the bike will almost die but then as i sit with clutch in it will slowly idle back up also lay on it and black smoke will puff out the exhaust when i got the bike it already had the SE a/c and the thunderheader also it came from a HD dealership so i would assume it has had a stage 1 comp mod, now i have changed the exhaust i took the 2in1 off for a couple months and ran V7h straightshots now have the 2in1 back on is it poss the comp has forgot the stage 1 because of the exhaust change? also, is the PCIII easy to install? or is there alot more to it than the Fuelpak?
Thanks again
Paul
Thanks again
Paul
Installing the PCIII should be about the same as installing the Fuelpack. It's setting them up once installed that will be different. The Fuelpack has you enter a series of codes based on your current set-up. You can get a PCIII from Fuel Moto already programmed with a map for your set-up, or have it dyno tuned.
If the EFI computer onboard was reprogrammed and is now running rich, then none of the foregoing options you mention will address your problem. That is because they are piggyback units and will only enrich the existing setting. They do not override the EFI computer to lean out the mixture.
I would have a dealer you trust reprogram the EFI; or, see if there's a way to reset the EFI to your stock settings. If you could do the latter, then a piggyback system would be of benefit. I run a Dobeck Techlusion ... also a piggyback unit. Like many systems, it has three-way adjustability, but will only add fuel (Dobeck makes the unti that some other sellers put their label on).
In your situation, I think it may be worthwhile to buy a Screamin' Eagle Race Tuner (SERT). It will be fully programmable and can address the issue of your bike being too rich.
ok well i have given the SERT some thought also now with the SERT will i be able to install it myself? because i want to be able to install the tuner myself and i dont want one that has to be dynoed
My understanding is that SERT has a link to use a laptop computer to install the fuel map (comes on a CD). I believe it is something you can do yourself ... also someone with a dyno can fine tune. If you're planning on doing more engine work later, this should be something that will be 'durable' ... you won't have to change it or upgrade it later.
I don't have first hand experience with it, but have read quite a bit about it. I was planning on going with it myself, but it's a little pricier than TFI.
I think that if your current situation is running rich, you've got to consider how to address that; and I don't think you do that by getting an 'add-on' or 'piggyback' type system.
