removing primary components
Old Feb 9, 2009 | 10:17 PM
George D's Avatar
George D
Default removing primary components
I had to lay my 97 Dyna Super down a couple of weeks ago and bent the shifter shaft that runs through the primary chaincase. So I have to remove every thing including the inner case. My question is will an electric impact wrenches take off the Jamnut and the Compensating sprocket nut. I can't afford to take it to a shop and I sure can't afford to buy a compressor big enough to drive air tools. Any info on this problem will be appreciated.
Old Feb 9, 2009 | 10:33 PM
mtnlvr's Avatar
mtnlvr
Most people say impact on the comp is bad, unless you're gonna replace it.
Is that the trick where you cut a flat metal bar to fit diagonally between the 2 sprockets to jam them from turning? Or I suppose the chain tensioner is in the way?
You can also try having a friend (the bigger, the better) sit on the bike with the front wheel against a wall and the rear brake applied while in 4th gear or so to keep the rear wheel from turning while you lay into a cheater on your breaker bar.
I used an air impact and got lucky...so far.
Old Feb 9, 2009 | 11:35 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Better get a service manual and be sure to check and see if the jam nut is left hand threaded. You need a primary locking tool as well. Don't forget the comp nut is probably red loctited on so a little heat may be necessary.
BIGJOHNXISMC
Jun 26, 2015 08:45 AM
HWill
Oct 17, 2012 07:32 PM
madsciontst
Shovelhead
Sep 5, 2011 02:30 PM
scubaharley
Jun 17, 2011 08:02 AM
96roadking
EVO
34
Feb 21, 2011 05:09 PM
