HELP! I need some ideas for engine mod
Old Feb 17, 2009 | 09:01 PM
cjm8806's Avatar
cjm8806
Default HELP! I need some ideas for engine mod
I have an 07 Street bob (96 cu.)
I have about 2,000-3,000$ to spend on some engine mods, i want to bump it up to a 103 , and possible port and polish the heads but thats about all i know to do. i dont know to much about engine work and would like some help.
If you have ANY ideas please let me know!!!!
Old Feb 17, 2009 | 09:21 PM
cjm8806's Avatar
cjm8806
cmon no wrench heads on right now or what????
Old Feb 17, 2009 | 09:52 PM
cjm8806's Avatar
cjm8806
bump bump bump
Old Feb 17, 2009 | 09:53 PM
SuperFastGlide's Avatar
SuperFastGlide
be patient, there not currentlly online lol... gear driven cams?
Old Feb 17, 2009 | 09:58 PM
archergodwin's Avatar
archergodwin
Different: pipes, intake, tuner, cams, roller lifters, throttle body and big bore kits for the top end. Truing and welding your crank, Timken bearing conversion, SE compensator for the bottom end.
What do you want your bike to do?
... BTW, if you say make gobs of horsepower, then you've bought the wrong bike
Old Feb 17, 2009 | 10:18 PM
cjm8806's Avatar
cjm8806
haha, i should have mentioned whats on it
V&H big radius pipes
SE High flow intake
30 tooth front sprocket (stock is 32)
I really like low end, what does the gear driven cams give you?
Old Feb 17, 2009 | 10:20 PM
cjm8806's Avatar
cjm8806
im also going to put a power commander on it but obviously not until all the changes are made
Old Feb 17, 2009 | 10:21 PM
reded's Avatar
reded
First and foremost is to make sure that the lower end is up to snuff. I would have the crank trued and welded and timken conversion done. At this point the lower end will be pretty much bulletproof for the common man. Everything else is pretty much just trivial. A good port job on the heads mated with the correct cam and pistons will yield great results.
Talk to the many builders out there and see what they recommend for your type of riding and are willing to back up with dyno proof. Thats not to say that your motor will perform exactly like the sample motor but at least you know it will be close. I don't put much faith in dyno sheets as I believe the dyno should only be used as a tool in order to extract as much power as possible from any given engine combination.
Lastly, prepare for the worst in terms of dollars cause if you plan to spend $3000, you will, at some point during the build, decide to go ahead and spend $4000. Trust me I've been through this process in 4 different forms of motorsports. At this point, I'm taking the cams and tuner route because I know too well that once you get deeper than that you reach the point of no turning back and you may as well do it all and do it right.
Old Feb 17, 2009 | 10:31 PM
cjm8806's Avatar
cjm8806
Thanks very helpful, Now would a reg. mechanic and or harley dealer weld the crank and do the timken conversion???
Old Feb 17, 2009 | 10:47 PM
reded's Avatar
reded
Not likely. It will need to be sent to a shop that specializes in that type of work.
