do the 96"s overheat?
Old Feb 20, 2009 | 03:15 PM
jhall201's Avatar
jhall201
Originally Posted by SBRob
I know about the parade mode, but I thought that was only installed on baggers.....I'm gonna save up my nickles and dimes and get a SERT installed and have it dyno tuned for a/f ratio down the road.
I have the SERT installed on my bike. Bike has never run better and you won't be sorry you spent the extra money.
Old Feb 20, 2009 | 03:16 PM
Tony P's Avatar
Tony P
Originally Posted by KBFXDLI
The TC96 does not "overheat". It does run hot because it is a stroked version of the TC88 and there is a larger rotational mass with the engine internals which generates more heat. Add to that more stringent lean tuning to meet EPA emission regulations and you have an engine that will approach 300*F on a hot day in slow traffic. But all you have to do is use sythetic oil and you are fine as the syn oils handle 300*F with no issue. .
"It does run hot because it is a stroked version of the TC88 and there is a larger rotational mass with the engine internals which generates more heat."
Huh?
Old Feb 20, 2009 | 03:58 PM
cpl215's Avatar
cpl215
This can be countered by increased rotational forces of the wheels which is generated by the rotational forces applied to the throttle.
Old Feb 20, 2009 | 04:50 PM
Gwjvw's Avatar
Gwjvw
My 08 got so hot it shut off on me! So i know mine runs hot!
Old Feb 20, 2009 | 05:55 PM
Dyna-Asa's Avatar
Dyna-Asa
is there a "safty shut off" it it starts to get hot enough to hurt the thing?
Old Feb 20, 2009 | 06:26 PM
Nemosengineer's Avatar
Nemosengineer
My '09 FXDC runs no hotter than my '07 XL1200R, the Sportster when it was hot would ping harder than a x-wife with canceled credit cards when you got on it hard, the Dyna is ping free so far but summer is the true test...
Best Wishes: Mike
Old Feb 20, 2009 | 08:43 PM
SGMAN's Avatar
SGMAN
Default Running Temp?
Does anyone even know what the temp is that your 96 runs at? I'm looking for a temp gauge in the dip stick for a 08 fxdc so I can do a before and after with my V&H exhaust . Only one I can find is 62938-00D on page 160 for 99-05 Dyna but need one for 08
Old Feb 20, 2009 | 09:47 PM
cpl215's Avatar
cpl215
I don't know if they overheat or not. I know they get hot as hell. I also don't know anybody that has had any serious damage from it. Do any of you?
oldtimer61
Oct 21, 2009 05:01 PM
masterblaster
Oct 30, 2008 07:29 AM
martin1
Aug 9, 2008 11:48 AM
jmacdonald5
Jul 31, 2007 01:11 PM
dlongo8241
Feb 22, 2007 11:49 AM
