06 rotor update
Old Feb 25, 2009 | 11:31 AM
thedonthere's Avatar
thedonthere
Default 06 rotor update
OK did my rotor upgrade this morning. Obviously I can weld better than I can take photos. When get home I will take a better photo and post it. I tig welded (2) tacks on each bolt head and used a little 308 stainless rod for filler metal. I am 100% sure I will not have the bolts back out now. Total cost is right at $74.00 for this upgrade. Still waiting for my timken IPB to be able to put back together. I have much more peace of mind now.
Old Feb 25, 2009 | 11:54 AM
AdrianVall's Avatar
AdrianVall
Nice!!! Was it difficult taking everything apart? Guess you must be good at this whole wrenching thing. I had mine replaced with an 07+ welded stator when mine went out under warranty.. (I had a few days left on the warranty too!! PHEW!!)
Old Feb 25, 2009 | 12:17 PM
thedonthere
Adrian it's not too bad to R&R the primary. First time about 2 hrs. After having done it once I can remove the primary in about an hour now. You can do alot to our bikes with a manual, lift and a few tools. To know what tools I need I just start on something and go as far as the tools I have take me then I go purchase what I need to finish.
Old Feb 25, 2009 | 12:42 PM
07bobber's Avatar
07bobber
Thanx for the pic.....cant wait to see more....
Old Feb 25, 2009 | 12:53 PM
Goddahavit's Avatar
Goddahavit
I really wish I knew what stator was in my bike, with a build date 2 months after yours, I'm thinking it may be the 2 piece.
i guess i'll find out eventually..
Thanks, for the pictures, that way i know what im looking at anyway....
Old Feb 25, 2009 | 02:00 PM
r00k's Avatar
r00k
I'm thinking you don't have a macro lens.
Nice work, what sparked you to go ahead and do this? Is it just a preemptive strike against the stator?
Old Feb 25, 2009 | 02:11 PM
thedonthere
Why I opened my primary was, I changed wheels and tires as part of my winter mods. I needed to change the drive belt to accomidate the new rear pully. So since I was already there, I went ahead and preformed a little preventive maintenence. My labor is free to me so why not. $74.00(gaskets,oil etc.to put back together) is a small price to pay for peace of mind.
Old Feb 25, 2009 | 02:23 PM
lowrider966's Avatar
lowrider966
What specialty tools did you need, if any. I know I'll be doing this fix one day. Trying to get as much info. as I can....thanks.
Old Feb 25, 2009 | 03:03 PM
thedonthere
To remove the primary you need a primary locking tool. I made mine. A piece of steel 7" long, 1" wide and .5" thick. It wedges between the clutck sprocket and the compensating sprocket so you can remove the bolts.
Old Feb 25, 2009 | 03:58 PM
JRK5892's Avatar
JRK5892
awesome work on this one! when i pull my primay aprt for powder i may have to do the same
HoolyNI
Sep 27, 2013 03:29 PM
Gatone13
Jul 25, 2012 11:24 PM
baxter
Aug 29, 2011 02:35 PM
dogcop727
Oct 11, 2010 02:05 PM
bigheaded2
Sep 29, 2009 08:07 AM
