remove turn sigs
Old Feb 25, 2009 | 06:29 PM
DavidD's Avatar
DavidD
Default remove turn sigs
I want to remove front my sig's. does anybody have instructions of were and how to unplug the the front sig's?
Old Feb 25, 2009 | 06:31 PM
anubisss's Avatar
anubisss
Under the tank...on the right side. Slide your tank back being carful not to puncture the crossover fuel line and unplug the connector. Manual has it all in there.
Old Feb 25, 2009 | 06:33 PM
jmpancoast's Avatar
jmpancoast
If you are riding an 06 or later, the plugs are easily accessible from just inside the rubber grommets on each side of the frame neck. Just behind the neck, on the underside of the frame, there is a plastic cover which conceals an additional access to the wiring. You may need to remove this cover to fish the signal plugs out.
Old Feb 25, 2009 | 06:35 PM
bberck's Avatar
bberck
Not sure what year your bike is but on mine (08), under the tank there is a plastic cover. You pop it out and all the wiring plugs are shoved in the neck of the frame. Once unplugged you can pull them out the side.
Removing the tank makes it eaiser but can be done by just moving it some.
Old Feb 25, 2009 | 06:47 PM
DavidD's Avatar
DavidD
it seems that I need to remove the tank? or do I just remove the tank bolts to give me room?
Old Feb 25, 2009 | 07:06 PM
bberck's Avatar
bberck
Many have done it without removal but I had mine off at the time.
c-note
May 25, 2015 10:10 PM
civilbob
Jun 18, 2013 12:02 AM
Hammy
Mar 19, 2009 02:46 PM
airvette
Sep 18, 2008 06:58 PM
hambone215a
Mar 2, 2007 12:24 AM
