Drain Plugs
Old Feb 25, 2009 | 08:17 PM
skip3406's Avatar
skip3406
Gasket Service Kit P/N 17369-06
Has the 3 O-rings and the clutch cover gasket all for $2.80
Old Feb 25, 2009 | 08:54 PM
devils haircut's Avatar
devils haircut
Man I really could have used that info earlier today when I was trying to order o-rings and gaskets from the local indy shop. How many times can you reuse the derby cover gasket? I know you aren't supposed to, but delicate hands make it possible sometimes.
Old Feb 25, 2009 | 08:59 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I reuse my derby orange oring gasket about 3 times. I also replaced those stupid torx screws with allen headed SS socket cap screws from true value for $2. Take one out and go match up the thread I think it is #20 3/4" long coarse thread but check. I torque them to 100 INCH lbs.
And check out Zanotti's HD on line for parts...usually 20% off. If you buy in quantity it makes sense for the shipping
Old Feb 25, 2009 | 09:25 PM
INTHERED's Avatar
INTHERED
Originally Posted by wolfydude
Never thought to check my oil plugs for any sign of thread lock already on them.Thanks all for your help.Wolfy
I think the thread sealer is a carry over from earlier years when the plugs did not have o-rings. I think proper torque and a new o-ring is sufficent.
Oh yea the thread size on the derby cover screws is 1/4 x 20 which is the same thread size as the primary, transmission & cam cover screws.
Inthered
Old Feb 25, 2009 | 09:30 PM
Gary7's Avatar
Gary7
Originally Posted by anubisss
Just make sure it has the o ring and it's in good condition.
Yup, that's all I did. No drips so far.
Remember to clean the plug and o-ring with brake cleaner, then lube the o-ring before you screw the plug back in.
Old Feb 26, 2009 | 12:02 PM
wolfydude's Avatar
wolfydude
I read somewhere on another thread,when using any thread loctite it wont give a true reading with torque wrench.
Wolfy
Old Feb 26, 2009 | 12:07 PM
Lorance66's Avatar
Lorance66
you can pick up a little kit from the dealer with 3 o-rings and a new derby cover gasket for about 5 bucks. I'd say a little teflon tape or white loctite wouldn't be a bad idea.
Old Feb 26, 2009 | 12:38 PM
expolice's Avatar
expolice
You can get a 10 pack of o-rings at Lowe's, from their plumbing department. I believe the "size" is number 41. The number 40 will fit the Arlen Ness Big Sucker air cleaner housing/mounts where the banjo bolts go.
That's all I know for now...
Old Feb 26, 2009 | 12:56 PM
Lorance66's Avatar
Lorance66
that's good info. Just pick up a pack of those and re-use the derby cover gasket a few times.
Old Feb 26, 2009 | 03:06 PM
dyna07custom's Avatar
dyna07custom
NO loctite new O rings are cheap use 1
