Questions?????
Old Feb 26, 2009 | 02:19 PM
formike56's Avatar
formike56
Default Questions?????
What bike in the Dyna family has dual disc brakes?
Will it fit on a Wide Glide?
Old Feb 26, 2009 | 02:22 PM
Rauzer's Avatar
Rauzer
Fat Bob, the old Dyna sport. I guess if you had the correct lower fork you could do it. Dont they make a kit for yours??
Old Feb 26, 2009 | 02:30 PM
formike56's Avatar
formike56
Don't know if there is a kit. I have seen a thread on one of the forums that swapped them out. Can't find it now..... Dammit
Old Feb 26, 2009 | 02:52 PM
MZBuckeye's Avatar
MZBuckeye
I'm in the process of doing mine right now. Mine's an 05 Custom with 39mm forks; Harley makes a conversion kit for it. Here's my thread about it, but I'm stalled right now waiting on a replacement bushing.
https://www.hdforums.com/forum/dyna-...kit-today.html
As soon as I get this damn bushing, I'll wrap up the install and finish my write-up.
What size forks does the Wide Glide have?
Old Feb 26, 2009 | 02:54 PM
formike56's Avatar
formike56
The Wide Glide have 49mm....
Old Feb 26, 2009 | 03:05 PM
Rauzer's Avatar
Rauzer
I would think if you got the set up from the Fat Bob it would fit on the WG. Arent they the same forks??
Old Feb 27, 2009 | 06:52 AM
formike56's Avatar
formike56
Went to the dealer last night was looking at the fat bob. The forks are 49mm with the dual disc set up. Exactly what I want... Now all I need is the $$$.... I would like to put the complete front end on my WG.
Old Feb 27, 2009 | 07:57 AM
sporty79's Avatar
sporty79
I did it on a St. Bob with V-rod forks:
https://www.hdforums.com/forum/dyna-...disc-dyna.html
With the wide glide, you may be able to use the right side leg from a fat bob. Might need a spacer for the rotor. IS the WG hub set up for dual discs? Start with an 08 parts manual and compare the part numbers.
jminor06
May 30, 2015 02:08 AM
feguy1
Nov 16, 2014 09:52 AM
supermanotorious
Sep 14, 2014 01:08 PM
mhenry
Dec 20, 2011 06:13 AM
jbmunnoch
Nov 20, 2009 09:54 PM
