Trees for a 14' Dyna
Old May 27, 2015 | 11:13 PM
jminor06's Avatar
jminor06
Stage II
Default Trees for a 14' Dyna
i recently bought a 2014 Dyna Fat Bob for my wife and I'm trying to use the 23" front wheel off of her old 1992 Dyna, doesn't fit. The 92 was thrown together with quite a few different bikes parts and I'm seeing now the trees and forks must be after market. I guess my question is does anyone know where the best place and most cost effective to find some wider trees that I could use existing forks?
Old May 28, 2015 | 04:30 AM
wastedranger's Avatar
wastedranger
Are your forks 39 or 41mm? Not sure there are wide trees for 39's. And will the trees hook up to a new Dyna? Redesigned in '06. Best bet is jp. Good luck.
Old May 28, 2015 | 07:57 PM
jminor06's Avatar
jminor06
Stage II
wastedranger.... they are acually 49mm. After doing some research today I have found out I need a set of 49mm wide glide trees. I've looked all over ebay and they are hard to find, any help from guys on here would be great. Thanks
Old May 29, 2015 | 04:31 AM
wastedranger
I'm a little confused. I know the fat bob has 49's. It has wide trees as well. The only difference between fat Bob and wide glide trees is wg has a little extra rake built in. I thought you wanted to put front end off old bike on new fat bob. If the old bike has 49's which I'm doubting then there isn't an issue.
Old May 30, 2015 | 02:08 AM
p51bombay's Avatar
p51bombay
Yep - already has wide glide width trees. As far as the wheel goes.........buying a brand new FB and sticking a (old, unknown) 23" wheel on it is going to look...................dumb, sorry, no other way to put it.
greenguyshrek
Jun 8, 2017 10:38 AM
Scootertrash60
EVO
Nov 4, 2016 07:07 AM
CWS
Sep 15, 2016 06:35 PM
Parkerhd36
Aug 30, 2011 08:35 PM
joemacro65
Jan 24, 2008 05:17 PM
