Fatbob front brake lines.
Old Mar 2, 2009 | 10:36 PM
MNrider's Avatar
MNrider
Default Fatbob front brake lines.
Anyone know the correct fittings for a 2008 Fatbob? I'm putting taller risers on, about 3" taller. I measured the stock lines and figure that I need 20" lowers and a 24" upper. I have been looking at the Russell Cycleflex stainless line kits. I can find some that are close in those lengths, but all the different angles and stuff has me confused.
Thanks.
Old Mar 3, 2009 | 01:00 PM
mynzbtr1's Avatar
mynzbtr1
I ended up putting 8 inch risers on my fat bob. I went to harley, they ordered a new set that was four inches bigger than stock
Old Mar 3, 2009 | 01:46 PM
glide05's Avatar
glide05
I have only seen the Russel Cycleflex kits for Metrics?
I would suggest that you use a Russell or Goodridge tee fitting under your lower tree. this will mean a 4 piece system for you (upper line, tee, 2 lower lines).
The advantage is - you can change the handlebars/risers in the future, and only need to replace the upper line
Old Mar 3, 2009 | 11:52 PM
Los11's Avatar
Los11
Hey can you post a full pic of your FB with the riser and all want to se how it looks I was thinking of doing 8 inchers.... Thanks
Old Mar 4, 2009 | 06:59 AM
Dooley's Avatar
Dooley
Double that request for more pics.
I am also thinking of taller risers, but would like to keep the stock black look.
pettifogger1
Feb 19, 2016 02:21 PM
sroc3
Jun 22, 2015 09:02 AM
tray45
Jun 7, 2011 04:11 PM
treynolds155
Apr 12, 2009 04:49 AM
drumer66
Nov 28, 2006 07:26 PM
