Dyna MC Batteries
Old Aug 25, 2017 | 01:15 PM
  #31
ABQ-Jammer's Avatar
ABQ-Jammer
Originally Posted by mud
check all of those carefully before you buy for 006 and newer Dynas.
006 up has a very tight fitting battery box.
I know in my experience the InterState/Yuasa
would not go in without forcing it,
and would not come out short of a prybar.
I sent it back and went with the HD.
I did a lot of research as well,
looking for a high performance unit to crank my hi compression motor.
and I just could not find any hiPower batts to fit into the compartment.
The HD cranks just fine though. no issues.
Also, each manufacturer rates cranking using different formulas,
and they can be very misleading.
mud
With the tight battery boxes, you can typically still get a thin silk ribbon under and between the battery and the box, and the ribbon is usually strong enough to use to pull the battery out. Just tie the ends together on top, and leave enough for a "handle", and next time you need to remove the battery, just pull the ribbon handle to get it out. Has worked for me on other bikes that were tight. Usually, the missus will have some ribbon laying around, and you can use a little of it, maybe a foot to a foot and a half should do, I think.
Old Dec 2, 2017 | 10:19 PM
  #32
HDSlimJim's Avatar
HDSlimJim
Originally Posted by KBFXDLI
other that fit:
Walmart (Yuasa) TX20HLBS 270CCA $69
Note: ALL are AGM sealed batteries.
At my Walmart, those Yuasa batteries are not AGM/sealed...the acid comes in a separate bottle...you have to fill the battery and then charge it before install.
Old Dec 3, 2017 | 11:34 AM
  #33
NorthWestern's Avatar
NorthWestern
Well, he did post that over 8 years ago
Old Dec 3, 2017 | 09:46 PM
  #34
wyotana's Avatar
wyotana
My battery was pretty close to dead today, lasted 7 years (Harley Battery), luckily I work for Interstate batteries and get a pretty hefty employee discount
oldmisfit
Apr 18, 2014 11:57 PM
xbox
Feb 8, 2012 05:31 PM
darylnj
Sep 20, 2011 06:31 PM
RutRoo
Apr 15, 2010 08:26 AM
Shrink
Jul 8, 2009 05:13 PM
