Fall away check?
Old Mar 8, 2009 | 11:06 AM
YellowHawk's Avatar
YellowHawk
Seaox, I checked my tank bolts....I had read that on here too. They were tight.
Old Mar 8, 2009 | 11:21 AM
Roadman56's Avatar
Roadman56
Default Fall away
I changed the triple trees to after market ones and when I pulled the front end apart it was noted that lower bearing is a press fit. I just fell off the lower tree when I removed it. I feel the there is too much slop in the fitment of the bearings to the stem causing the clunk. The clunk was gone when when I tested the new assembly out.
Old Mar 8, 2009 | 12:55 PM
BlackSpecial's Avatar
BlackSpecial
Originally Posted by YellowHawk
I don't know why they didn't do it.....
Well to be honest with you.....I'm not positive my dealer did the fall away check either.....but after install of the kit (under warranty) the clunk is gone.
If I should get it back....I'll check the fall away myself like you did.
Old Mar 8, 2009 | 01:37 PM
YellowHawk's Avatar
YellowHawk
Well, since we're being honest, I guess I'm not positive my dealer didn't do it....I really thought it would take a lot longer. I didn't take long at all for me to do it so I guess my dealer would've had time to do that. I assume they did not since the clunk was still there. Like I said though, I did not tell them I wanted the new washer in hopes that it would fix the clunk.
Old Mar 8, 2009 | 02:54 PM
BlueSoftail's Avatar
BlueSoftail
I have the same problem with my softail, found following link on the Web which I plan to follow to correct my clunk. Looks like this in part is caused by gap between stem and hole in the triple tree. See link...
http://www.kenandjudy.us/Harley%20Pi...lunk/index.htm
Old Aug 3, 2011 | 07:29 AM
escherWG's Avatar
escherWG
Originally Posted by seniorsuperglideE8
I got rid of the clunk after reading my service manual, something that will spell out the fall away test. Anyways when you go to tighten the stem nut, loosen only the lower triple clamp (triple tree) bolts, tap the clamp areas with a rubber mallet or a deadfall hammer to loosen the fork tubes in the lower tree. Think about what is happening, you are ever pulling the upper and lower trees together so minutely but it happens, tighten the stem bolt and retorque the lower pinch bolts. Mine were 25-30 ft.lbs. (39 mm tubes).
So, for an 06 dyna, do you loosen the top or bottom triple tree bolts?
Old Aug 3, 2011 | 07:30 AM
escherWG's Avatar
escherWG
I've been having a problem with the front end clunk for several months. I took the bike to the HD dealer and had the new steering stem nut washer installed. They didn't do the fall away check, just changed the washer. It didn't fix the clunk. I am tired of hearing it and I'm afraid something's going to be damaged. So....
I bought a motorcycle jack today and I want to do the fall away check and adjust the star nut to tighten things up. Two questions.... I don't have the adapters for the Dyna. What do you use to jack yours if you don't have the adaptors? I have the service manual and I've read the procedure for the fall away check/adjustment. Are there any tips/techniques that would come in handy before I get started? I'm a little nervous about taking the upper triple tree loose to get in there and adjust.
this is why i ask. upper and lower are both mentioned. but i thought only one should be loosened.
Old Aug 3, 2011 | 08:22 AM
08fxdf43202's Avatar
08fxdf43202
I loosen the top tree. I leave the top stem nut on the last couple treads. With the top clamp loose I'm able to pull the handle bars & clamp up for clearance to the star nut below the top clamp.
Old Aug 3, 2011 | 09:59 AM
escherWG's Avatar
escherWG
thanks 43202.
what are the disadvantages of over tightening the steering head? is it just that the bars/fork/wheel will be hard to turn? or are there any of other issues with having it tighter?
Old Aug 3, 2011 | 10:19 AM
128auto's Avatar
128auto
You know what? I've never done any fall away test, remember how you adjust the car tapered wheel bearings on old days? Bike off the ground, losen upper tree clamp bolts, snap bearing bolt tight with a adjustable wrench, move the steering left and right, back the bolt off, snap it tight again then back it off, tighten it with a pair of pliers until it stops, you don't have to force it. I've done this on many bikes both metric and Harley never had problem, vibration what so ever.
