Fall away check?
Old Aug 3, 2011 | 10:23 AM
escherWG's Avatar
escherWG
Originally Posted by 128auto
You know what? I've never done any fall away test, remember how you adjust the car tapered wheel bearings on old days? Bike off the ground, losen upper tree clamp bolts, snap bearing bolt tight with a adjustable wrench, move the steering left and right, back the bolt off, snap it tight again then back it off, tighten it with a pair of pliers until it stops, you don't have to force it. I've done this on many bikes both metric and Harley never had problem, vibration what so ever.
oops, misread
Old Aug 3, 2011 | 11:21 AM
escherWG's Avatar
escherWG
alright I'm going to give it a try.
here are the steps:
1) put it on jack - front off ground.
2) loosen upper triple tree pinch bolts
3) pull up on handlebars to expose nut
4) turn nut clockwise to tighten.
5) tighten upper clamps
6) lower bike and let 'er rip!
that sound about right??? 06 dyna wide glide
Old Aug 3, 2011 | 04:16 PM
08fxdf43202's Avatar
08fxdf43202
Yep, but before you take it off the jack turn the front end side-2-side to be sure there's no binding sound/feel in the bearings.
Ridewva
Oct 4, 2016 12:47 AM
rleedeuce
Oct 4, 2012 06:38 PM
CSS_FXD
Mar 25, 2012 04:41 PM
crepe
Jun 25, 2010 05:43 PM
icecaps
Mar 12, 2009 06:04 PM
