Raising the Dyna - suspension upgrades
Old Mar 12, 2009 | 07:16 PM
  #31
SC-Longhair's Avatar
SC-Longhair
You definitely have an interesting ride. I'm sure it's a combination of the taller shock and its a better quality shock.
Old Mar 12, 2009 | 10:33 PM
  #32
Centerline's Avatar
Centerline
Originally Posted by Shag67
Oh... while we're showing off pegs... here's the left peg off of my Warrior *after* I'd raised it up...
RIDE THE DAMN THING!!!!!!!!
****, I loved that crazy nutz Warrior of yours; the grenade, spikes and all. Too bad you ain't gonna make the W' Fest, we were sure to have a good Harley showing.
Old Mar 12, 2009 | 10:38 PM
  #33
Centerline's Avatar
Centerline
Originally Posted by Lopoetve
What all do you have on there? I recognize a FatCat or simiar 2-1, and hte Heavy breather, is the 103" just the stage 1 kit or do you have a cam swap in there too?
It's a 103". In the SE pro catalog they call it the SHO... CNC ported, 260 cams, 10.5 HTCC pistons, some odds and ends.
Old Mar 12, 2009 | 10:39 PM
  #34
Lopoetve's Avatar
Lopoetve
quick question - any issues fitting those ohlins (36e 215) to an 09 Superglide custom?
Old Mar 12, 2009 | 10:40 PM
  #35
Lopoetve's Avatar
Lopoetve
sweet, k, taht makes sense. Was curious where you got 35hp on me, since I didn't think a 103 on its own would do it - the cams and pistons would do the job though, especially with a head job I'm at 77/96 right now, on the stock 96" with just the bolt-ons.
Old Mar 12, 2009 | 11:48 PM
  #36
gregbenner's Avatar
gregbenner
I'm not sure of the differences between a Superglide and a Superglide Custom? Wouldn't think you would have any issues though. I (and also Havoc I think) had to play around a bit with the included spacers to get the right fit, but not what I would deem an issue.
Old Mar 12, 2009 | 11:59 PM
  #37
Lopoetve's Avatar
Lopoetve
spoke wheels and chrome I think... I don't think the custom is any lower. oh, and a bigger gas tank. What all did you ahve to do with the spacers?
Old Mar 13, 2009 | 12:07 AM
  #38
gregbenner's Avatar
gregbenner
Not easy to describe...the instructions are rather "universal". I deleted the inner spacer at the bottom, otherwise the bottom of the shock extended too far out, on the left side I added a spacer on the outside, otherwise the bolt was too close to the pully. Pretty minor stuff I think.
Old Mar 13, 2009 | 08:50 AM
  #39
Lopoetve's Avatar
Lopoetve
These all spacers included, or something you picked up from a parts store? Thanks for your time too!
Old Mar 13, 2009 | 09:21 AM
  #40
gregbenner's Avatar
gregbenner
Mine came with a bag of hardware, sort of a universal kit as near as I could tell. Numerous spacers, washers and a couple bolts. I just figured out which spacers I needed, and it was not an issue. Install instructions weren't teriffic, but then I suppose installing shocks on a Dyma is pretty basic to someone who has done it.
The instructions to setup and adjust the shocks were far better I just put in on the jack, then took maybe an hour. I am NOT mechanically inclined
