tombstone tailight....thoughts?
Old Mar 11, 2009 | 12:27 PM
jefx's Avatar
jefx
Default pics of tombstone tailight....thoughts?
I picked up a tombstone tailight on ebay for $15 and thought I'd play around with it. It's definitely not a direct bolt on, but that's not a problem. I spraypainted it black and mocked it up just to get a feel for it.
Here's the problem...It covers up the fender holes for the license plate, so a relocation is in order.....but I have throw-over saddlebags.
I guess the only option is a ghetto-looking mount of the plate on the bag.
Here's some pics of the mock-up. Please tell me any thoughts/concerns/ideas that you might have. All comments welcome....even the smartass ones .
Old Mar 11, 2009 | 12:51 PM
bdavis385's Avatar
bdavis385
I love tombstone taillights. Would love to have one on my Heritage, but have other items with a higher priority. Looks good.
Old Mar 11, 2009 | 02:03 PM
glide05's Avatar
glide05
the constabularies around here don't really bother motorcycle riders too much.
they let just about everything go, as long as you're not ripping it up and bothering other taxpayers..
not sure where you live - but here ... mounting a tag like that on a removable unit, without a tag illuminator would get you pulled over for sure.
Oh ... since you asked - it does look ghetto ............ like the lamp though .....
Old Mar 11, 2009 | 02:06 PM
JRK5892's Avatar
JRK5892
Looks fantastic!!!
Old Mar 11, 2009 | 02:31 PM
jefx's Avatar
jefx
ok. Thanks guys. I do really like the look of the tombstone myself. Of course I'd give it a better paint job and more symmetrical final mounting position if I go this route.
glide05....your post was a little over my head...But as far as lighting, I'd use the turn signal (wired up as a running lamp). By drilling/filing a small hole in the bottom of the lens cap, I'll have that area illuminated without any extra lighting. Also, the plate mounted in the pic is just taped to the bag for mock up purposes.
I never considered it illegal to have the plate mounted to a removable object (like a saddlebag)......However, even the stock plate holder is removable, so what really defines "removable"?
It's definitely ghetto, but is it too ghetto
Old Mar 11, 2009 | 02:39 PM
ratt196635's Avatar
ratt196635
I had one on my 06 and had to fab a special mount to hold it on and still use a plate mount then ended up having to make my own laydown plate mount in order to get a plate mount to work but i got it done here is a pic with the stock plat holder.
Old Mar 11, 2009 | 02:49 PM
jefx's Avatar
jefx
Looks good. Thanks for the ideas.
Old Mar 11, 2009 | 02:57 PM
ratt196635's Avatar
ratt196635
I still have the way i mounted it somewhere the light got trashed when i got rear ended but what i did was drill a 1/4 20 i think hole in the back bracket and run a long bolt through to the tab where the old tailight bolted and put a lock nut on it with lock tight that way it was low enough to use the holes for the licensee plate bracket ill look and see if i still have that part and take a pic and post it so you can see where i drilled the hole. But i may not still have it since the only parts that survived was the outer houseing and the inner mount.
Old Mar 11, 2009 | 03:32 PM
HDDyna2006's Avatar
HDDyna2006
You should lower it a little bit more, it looks sticking up some, and maybe the plate holes might be usable, or drill 3 more hole in fender.
Old Mar 11, 2009 | 03:52 PM
jefx's Avatar
jefx
Damn. Sorry to hear about that.
That's what I planned on doing. I didn't think about lowering it enough to use the stock holes....too bad I already painted over the window .
Ya, I plan on straightening it out and lowering some when I mount it. That's just where I could get it balanced well enough to take a picture.
