Preferred tire pressure?
Old Mar 11, 2009 | 01:55 PM
07bobber's Avatar
07bobber
Question Preferred tire pressure?
How much air do you normally run in your tires when your riding solo?
Old Mar 11, 2009 | 02:18 PM
kk6pg's Avatar
kk6pg
Chris,
The book says 30/36.
When I'm out on the open road, I'll bump it up to 32/38
If I'm looking to shread the twisties, I'll take it down to 25/30
Normal commute back and forth to work goes at book.
Old Mar 11, 2009 | 02:51 PM
Topspin's Avatar
Topspin
Book 30/36
Me 34/40
Old Mar 11, 2009 | 03:13 PM
Man O'War's Avatar
Man O'War
32/38 solo. I check often because of the laced wheels. Pressure goes down 1 lb or so per week. When goes down to 30/36, I fill back up to 32/38. I always measure when the tires are cold.
Old Mar 11, 2009 | 03:37 PM
gunner11's Avatar
gunner11
36/36 one up 36/40 2 up.
The Ground Truth's Avatar
The Ground Truth
Dealer who also rides a street bob told me 40/40
Old Mar 11, 2009 | 03:39 PM
07bobber's Avatar
07bobber
Im running 40/40 at the moment and the ride just seems so much more stiff rather than say 34/34
Old Mar 11, 2009 | 03:56 PM
bberck's Avatar
bberck
I run 32/36 after trying several pressures and thats what I liked best for a combination of riding styles.
Depending on your weight I may run more in the back. I am only 165lbs.
Old Mar 11, 2009 | 06:09 PM
maddoggreene's Avatar
maddoggreene
I'm 6'6" and 240 lbs and run 38 forward and 40 aft.
Old Mar 11, 2009 | 06:21 PM
madden23's Avatar
madden23
Some tires require more air than Dunlops, metz 880's run 40/46. Don't go by the manual if your running a different brand than Dunlops. Go by what the manufacturer specifies.
